Tiny coffee maker and toaster
wincrasher65
Found an easy compact item to make coffee, and I think I found the perfect compact toaster.
http://wincrasher.blogspot.com/2015/04/a-small-coffee-side-of-toast.html
2016 Winnebago Travato 59K, 2017 Allegro 32SA
Follow my blog: www.wincrasher.blogspot.com
Our Facebook group is: Class B Camper Vans
24 REPLIES 24
Cobra21
I bought a 1 cup Bella electric this winter for the RV, $20.00. It lasted for 6 cups. Now I have the 4 cup Mr. Coffee, hope this lasts. I got to have my morning coffee!
Brian
Escargot
wincrasher65 wrote:
Found an easy compact item to make coffee,....
A note regarding the Melitta type cone, collapsible or not:
After placing the filter in the cone and adding the dry coffee, pour just enough water to cover the grounds. This saturates and "opens" up the grounds. That water will also wick up the filter a bit and keeps the sides of the paper filter from collapsing into the wet grounds.
After the initial water drips out, continue adding the amount of water that will fill your cup.
I use the brown filters vs. the white ones because ... no bleach.
Edited to explain: I added this comment because several have complained about the paper filters in their Melitta cones collapsing.
2006 Pleasure Way Plateau TS, MB Sprinter
drsolo
I have used the same style coffee maker for the last 30 years, a 12 cup Proctor Silex coffee maker (now considered vintage, LOL). I stocked up buying the old version since it never overheats the water and over extract the coffee. My toaster is one that toasts bagels and muffins and since I never eat just one side or one piece of toast I need a 2 slot toaster. Both of these are tucked behind the cargo netting when not in use.
Ingrid and Dan Retired teachers from Milwaukee, WI
1992 GMC Vandura conversion
mkguitar
Got a $8 toaster at walmart works pretty good.
For coffee I went with a perculator as the genny is noisy...we always have gas.
Amazon about $30
mike
gerrym51
how about this.
i bought at a store for 3 dollars
melita
wincrasher65
Dakota98 wrote:
Here's an interesting article concerning the TOASTERS
They are a low wattage draw & great for the RV environment.
What a great link, thank you! I guess the one I have is the 1-A-6.
RoyB
We use the CUISINART GRIND and BREW 10-cup Fresh Bean Coffee maker with Thermo Carafe DGB-6000BCFR while we are re-charging our battery banks each morning around 8AM.
This brews up in around 5-minutes 2KW Honda Generator run time and then shuts off... We have HOT BREWED COFFEE in the Thermos Carafe for the day.
We use the hot grille for our toast after we fry up our Eggs and Bacon...
Works for us just fine every morning...
No batteries or Power Inverter used in this operation...
Roy and Carolyn
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Dakota98
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
Pclind1950
We use a French press for our coffee. It doesn't take up much room and makes a great pot of coffee. We get about nice sized cups of coffee out of it. For toast, we use a small 2 slice electric toaster which we have room for.
Paul L
2012 Pleasure Way Plateau TS - MB Sprinter 3500
Merrykalia
I thought it was actually an electric pot with a toaster. I saw one of those at Big Lots a week or so ago.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
