I recently purchased my first RV (1998 Coachmen Catalina 22RK, Ford E350) and immediately replaced the 10 year old tires with new ones (Aeolus CrossAce HT AS02 LT225/75/R16). I've done a lot of reading about proper inflation pressures, but I have not been able to locate a weight/inflation chart for these particular tires. Can I use one from a different manufacturer?
Last weekend I loaded 'er up and had a shakedown overnight camping trip in a friend's driveway (went well, boondocked and used all systems successfully). On the way there, I stopped at the CAT Scale and got weighed. I only have axel weights, as I have not been able to find anyplace to get 4 wheel weights ...
Here's the info from my door sticker:
GAWR-- Front: 4200 PSI 65
Rear: 7800 PSI 60
GVWR: 11,500
Weights from the CAT Scale:
Front: 3480
Rear: 7680
Gross Weight: 11,160
This weight was with all occupants, full gas/LP, 3/4 tank of fresh water, about 1/4 full gray/black tanks, and all gear.
So, I feel like I'm doing pretty well in the weight department, and I'm going to move some heavy stuff (drinking water) to the front passenger area (I travel alone with three dogs to dog events). Right now, the tires have 72psi. Can someone point me where to go to determine what the tire pressure should be at this weight?
Oh, and do I need the weight in the rig when I check/fill the tires (should I fill the fresh water tank back up)?
I'm heading out on my first big trip in 10 days (650 miles each way) so trying to get all my ducks in a row!
Oh, and this is a great forum!!!
Dog shows, racing and lure coursing with whippets!
My first RV, 1998 Coachmen 22RK, Ford E350 V10 Triton
