Oct-23-2021 04:33 PM
Oct-27-2021 05:15 AM
TechWriter wrote:larry cad wrote:TechWriter wrote:wjschill wrote:
Actually TOYO is a product of Japan, and most are built right here in the good ol' USA, in Georgia.
Um, better recheck that.
Wow!! That is an amazing list which seems to say, you probably don't know where your tires are made!
There's a tire code for that.
I have a feeling some of us will be surprised by the code on our tires.
Oct-26-2021 09:28 AM
Oct-26-2021 03:46 AM
Oct-25-2021 05:57 PM
Oct-25-2021 05:49 PM
wjschill wrote:
Tom/Barb...
Ease up dude..
Great thing about our country....We can have opinions without being put in front of a firing squad.
Life's short...Have fun!!
Skip
Oct-25-2021 03:49 PM
Oct-25-2021 03:25 PM
Oct-25-2021 02:17 PM
Oct-25-2021 11:20 AM
William B wrote:Tom/Barb wrote:Pangaea Ron wrote:
I also changed my Michelins with Toyo's. Michelin has had issues with sidewall deterioration.
Do you have a reference for that?
I've had 2 set of Michelins, they give a softer ride, and longer life.
Yeah, I had 3 sets crack badly after 3 1/2 years, enough I didn't want to drive on them anymore. Michelin gave me credit one time, and I switched to Toyo's and will never use Michelin again.
And as far as Michelin is a softer ride both my wife and I feel we are getting a better ride with the Toyo's.
Oct-25-2021 03:07 AM
Oct-24-2021 04:58 PM
Oct-24-2021 04:52 PM
wjschill wrote:
Just brought home, new to us, 2014 Tiffin Open Road 36LA.
It has the original tires with lots of tread, but bad looking cracked sidewalls.
The original tires are Michelins 255/80R 22.5 GXRV. I want to replace with TOYO brand. Will the TOYO 265/75 22.5 work as the replacement?
Thanks.
Skip
Oct-24-2021 07:48 AM
Oct-24-2021 07:10 AM
DrewE wrote:
There are a few considerations with changing tire sizes. It's hard or impossible to say which, if any, of these would cause you trouble without more information (specifically what information should be pretty obvious).
The overall diameter of the new tires is a slightly smaller, which means your speedometer and odometer will read about 1.5% higher than is correct--probably not enough to worry about.
The new tires are a little wider; there are a couple of potential concerns with that. First, if the rims are not wide enough, it may not be safe to use the wider tires with them; however, I highly doubt that would be any concern as it's not a big change in width. Perhaps more likely is that the clearance between the dually tires may become too small, leading to rubbing and/or overly reduced heat dissipation.
Finally, you also need to check the weight handling capacities of the two tires, and ensure the new ones are sufficient (and at pressures that are within the limits of your wheels). I doubt there is a lot of difference there, so you're most likely fine here.
My hunch is that the new size would be perfectly acceptable, but do double-check with someone who really knows what they're doing or talking about (rather than just me). If you happen to have a spare, whether mounted or otherwise, it needs to be the same basic size as the others, of course.
