tow package,
evanvalk
Any body know if a tow plate on the tow car can BE REMPOVED AND CHANGED TO ANOTHER CAR?. thank YOU.
ED. & ROSE.
Hartland Wilderness, 2014, 33.6 ft. 2-Slids.
2008 Ram 2500 Quad Heavy Duty 6.7,Cummins Turbo-Diesel
4X4 Big Horn. Tampa, FL
TAMPA, FL.
๐Ÿ™‚
4 REPLIES 4
super_camper
The other thing to keep in mind when removing the base plate is it replaces the bumper on many vehicles. If you didn't keep the bumper this will be a problem.
lj2654
usually most vehicles go through a design change after just a few years.....but if you have the bracket model number you can go to camping world site and check other vehicles part numbers against what you have! I have a bracket setup for a 2005 CRV and is only good for two years on that vehicle only....
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
goodcruisin
Agree with gemsworld with one small caveat. The baseplate for a 2003 Ford Explorer may be the same as a Mercury Mountaineer as it is realistically the same vehicle. BUT it may not be depending on the manufacturer of the baseplate. When I bought the baseplate for my Explorer I wanted one that was as hidden as possible. The Demco version had the connection points come through the facia area in place of where the fog lights would have been. Other manufacturers had the connection point below the facia.
John (USN Ret) & Debbie
Tux (Amstaff/Dalmation mix)
'96 Monaco Windsor 36' DP 8.3 Cummins for chillin'
985 HP Dragster for thrillin'
Community Alumni
Not applicable
Base plates are usually designed to fit specific vehicles. I seriously doubt a base plate designed for a certain make/model would work on a different make/model.
