Tow protection
Rwake901
Does anyone use a product called "Protect-a-tow"? The car we tow is starting to get some chips in the paint from towing it and I'm looking for something simple to use to protect the paint. I already have the large mud lap across the back of the Motorhome. Seems to get beat up the worse when driving in the rain. I thought about a bra on the car but hear those will rub the paint off too. Just was wondering how hard this Protect a tow would be to take on and off. Thanks
30 REPLIES 30
dtucker3usa
We use the rock guard from Roadmaster. Works pretty well.
Gjac
I made one out of old trampoline material when I went to Alaska. Also made a wind shield protector . The dirt roads and passing trucks threw a lot of rocks up and it worked as designed. After a month of driving I just used the wind shield protector. It is just added work when disconnecting the tow car, and not worth $200-$400 IMO. I never used it again after the Alaska trip.
obgraham
I used the similar Tow Defender (yes, that spendy one from Roadmaster) and was happy with it. Getting rid of the big mudflap, however, was a much better way to minimize toad rash.
GPWayne
"Protect-a-Tow" is about the best and least expensive protection you can get.
I can't see you making the same thing yourself for that cost.
I have used mine ever since our trip to Alaska and have been on lots of gravel roads here in the lower 48 and Mexico...No damage to toad and a lot cleaner, for sure! Super easy to install and remove. Best of all, stores in a small lightweight, provided bag.
We found other methods failed big time.
Tom_Barb
Dutch_12078 wrote:
Tom/Barb wrote:
WoW over 200 bucks for a over sized window shade.
http://protectatow.tripod.com
Price out a few yards of heavy PVC coated polyester mesh, if you can find it, and then add on about 20 feet of bungee cord, six snap clips, six eye bolts with double nuts and fender washers, 7 feet of 1/2" PVC conduit with two molded end hooks and two couplings, a grommet and 2 feet of smaller bungee cord, plus the labor and equipment to cut and sew the fabric, cut and sew the nylon material for the carry case, cut the conduit to size and install the couplings, print the instructions, and package the finished product. Now tack on a percentage for fixed overhead and profit margin and that $220 starts to look pretty reasonable...
Removed the flap, $0.00 problem solved.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
Mile_High
The Blue Ox KarGard II looks pretty sophisticated. I chatted with a guy at camp that had one and he likes it for his Silverado behind his Tiffen. After watching the video from E-Trailer, I'm a little concerned that it will strike the painted bumper on the motorhome in turns. The video has it striking a large metal bumper. I can't tell how low it will sit yet. (PS - 362.00 Amazon)
Blue Ox Video
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
Rwake901
Roadmaster makes about the same thing and it's around $400.00 So yeah they aren't cheap for what you get.
Tom_Barb
Dutch_12078
We've used our Protect-A-Tow on two different toads so far, and have been very pleased with the protection it affords. We particularly like that it protects not only the toad, but the tow bar, safety cables, and wiring as well. The extra minute it takes to hook it up is time well spent.
Dutch
TANDDANDBIGE
We use Protect-a-tow. It seems to work quite well and is easy to use. The price is reasonable compared to other like products. We like it.
2002 HR ENDEAVOR 40'
2007 FORD EDGE TOAD
egh33
I have a Bra for my 02 Jeep, I have one chip up by the windshield but I think it got there when it wasn't being towed. I always wash the Jeep and put a real good coat of Turtle Wax on after every trip. the Bra is taken off until next trip.
My Jeep is 14 years old and it looks almost brand new.
Now my Jeep is kept in the garage all the time except for trips.
Tom_Barb
mike brez wrote:
Sometimes the big rear mud flap is worse than not having one.
We found this to be true, the big flap is simply a big fan causing enough wind turbulence under the rear of the coach to blow up debris onto the towed.
we removed ours, and the chipping stopped.
wildtoad
The trick for car bras is not to leave them on all the time, and especially take them off after a rain to dry. You can also invest in one of many 3M clear film based products for your towed car.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Mandalay_Parr
I took my rear mud flap off. No more chips.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
