Traveling with battery inside
cctv
I want to transport a deep cycle battery in the outside storage compartment that has no outside venting. The problem is there is an opening to the inside living area of the RV so if there is any fumes they will get to us. My question is, if the battery is not connected to anything will it produce any fumes ?
8 REPLIES 8
Harvey51
Agree, no problem. I remember years ago getting acid holes in my coat after carrying batteries, nowadays it doesn't seem to happen. The battery caps must be tighter than they used to be. Maybe I keep them cleaner.
I wouldn't use a closed container. You can make a harmless bit of flammable gas into a bomb by enclosing it.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
cctv
Thanks everyone
j-d
Exactly. A Battery Box. Then pack stuff around the battery box so it can't slide around and possibly get up enough speed to overturn. Even empty cardboard boxes. We might panic stop faster than we'd accelerate so start out with it "flat" (long side) against the front end of the compartment.
ScottG
The simple answer to your question is "No" - it will not out-gas or cause any problems just carrying it inside the RV.
IAMICHABOD
Just put it in a approved transport case like One Of These and you should have no problems transporting it.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
mlts22
If transporting a battery, get a plastic case/box for it with a lid. Usually most auto stores, or even a Wally World should have these in a size that will fit the battery. As stated above, batteries do leak, and battery acid isn't fun stuff to clean up.
Trackrig
There shouldn't be any fumes since it won't be hooked up to anything. However, be sure to put it in something like a plastic bag and then inside of a cardboard box. There always seems to be some acid on a battery and you don't need it getting on anything.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
K_Charles
You aren't going to live with it there, just transport it. I see nothing wrong with that if it's not hooked to anything.
