Turn Signal issue on Holiday Rambler
KevinE
I went to go out this past weekend when I had an issue with the turn signal on our coach. When I parked it 2 weeks ago, all was fine. When I went to pull out of the driveway I pulled the headlights on. When I turned them on, the left turn signal indicator in the dash came on. I tried turning the left turn signal on, but the actual lights just came on solid with no flash. The right side worked fine. When I turned the headlights off, the left side worked correctly. When I started driving with the headlights on, after a few miles the indicator light on the dash went off and the turn signal worked correctly. It came on and off as I drove. I'm suspecting that its a bad ground somewhere, but I'm not sure. Was wondering if any other folks have had something similar. It is an 02 Holiday Rambler Endeavor diesel on the Roadmaster chassis. Thanks in advance!
9 REPLIES 9
wildmanbaker
KevinE wrote:
UPDATE: The harness leading to the turn signal was buried in the foam insulation in the corner. Once I dug through it, I found the connector was loose. Cleaned it up and reconnected it and secured the wire, problem solved. I think after it was on for a little, the ground heated up and started looking for a better ground somewhere. Thanks for the advise!
Good so hear that you got the problem solved, with good advice. Interment problems are very hard to find and solve. Thanks for getting back about the answer.
Wildmanbaker
KevinE
KevinE
Thanks everyone. I'll check out your suggestions.
sch911
It really sounds like a bad ground. Power is back feeding through the other bulbs on that circuit. Have seen similar issues many times on all types of vehicles.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
enblethen
Compare the lights on right with left to determine which is out.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
DSDP_Don
Before you go too crazy, follow "enblethen's" advice. Often just a bulb is out and it's a way of notifying you.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Rickieblue
It is a bad ground for sure..could be at the headlights or the tail lights. If it happens again, you need to visually inspect your lights for one that may be dim. If it was the headlight ground, they would be noticeably dimmer but you didn't mention anything about that..my 2 cents thinks it is in the tail lights.
2000 Damon Escaper...model 3980 Spartan Mountain Master Chassis
Cummins ISC 8.3 liter 330 HP, Allison MD3060 6 speed automatic
Pretty much bullet proof drivetrain
bullydogs1
Also check the bulb socket itself, almost sounds like the double contacts under the bulb are shorting or if the bulb itself melted at the base and is shorting with the parking light side of it.
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
enblethen
You have a lamp outage on the left side.
Bud
USAF Retired
Pace Arrow
