โNov-07-2012 09:07 AM
โOct-10-2013 07:06 AM
Ponder wrote:
Hi Tropical.
Pretty sure I selected the 20 amp circuit...it only goes to the Rear AC...the other circuit powers the front AC and all the rest of the 120 volt outlets. If I run the generator, everything works, and when I unplug the pigtail, the only change in the coach is that the rear AC goes off. I feel that the wire with the pigtail (connected to 3external 120 volts) goes to the Intellitec, as does the 30 amp from shore power go to the intellitec...so at this point, Intellitec sees shore power and does not allow the two AC's to run at the same time. Funny thing...I discovered that the rear AC will not run with the extension cord attached to the pigtail unless shore power is connected or unless the generator is running. I think it's the Intellitec EMU-2 that is contoling this. If I can find the wires coming out of the Intellitec to the rear AC, place a receptacle on the wires from the intellitec, and a plug on the wires to the rear AC...This way Make the split after the Intelletic...Would this make any sense? I split the rear AC circuit about 3 feet from the Generator....which of course is before the Intellitec EMU-2.
Thanks Tropical very much for your help again.......Ponder
โOct-09-2013 03:41 PM
โOct-09-2013 03:20 PM
Ponder wrote:
Hello Everyone.....I started this thread months ago but realized I was too new to RV-ing so I spent the summer learning some things and only being able to run one of the two AC's at a time on shore power. Both run at once on the generator, but only one at a time on shore pwr. Have 2000 Rexhall with Gererac with two breakers on the generator, each for 30 amps...although the schematic says should be a 30 and a 20. Also have two switches one for front AC and one for the Back AC Inside the coach. Also have Intelletec EMU-2 with transfer switch etc.
I found the J-box with the two circuits running through it from the Generator and installed the Receptacle and pig tale as discussed earlier in this thread....
With the generator running, both AC's work at once via the two switches inside...unless I unplug the pigtail from the outlet, then the rear AC goes off as you would expect. The front AC continues to run and the RV still has 120 volts at the receptacles. But with the generator off, and shore power connected with the 30 amp cord, and an extension cord from 120 volts at the shore power post to the pigtail plug I installed... can only run one AC at a time no matter what position the two switches are in for the 2 AC's.
I think what I have missed here is that both AC's are controlled at the Intelletec EMU-2 and so I am going to have to modify what I have done with the Receptacle and pigtail I think and move this set up elsewhere in the circuit in order to bypass the Intellitec EMU-2. But I am now over my head trying to figure out where and how in the circuits to do this...
Can anyone offer me some help and advise in doing this in order to work with the Intelletec EMU-2...I have the schematic from the manufacturer if this would help...
Many Thanks...Ponder
โOct-09-2013 03:10 PM
โOct-09-2013 03:02 PM
โNov-09-2012 11:51 AM
wa8yxm wrote:Ponder wrote:
Thanks Bob B for that........
Do you have an equally straight forward way to run both AC units from the generator. (no shore power) The coach has a switch that selects either AC unit but not both?? Thanks..
Ponder
Yes,, Set the Front/Rear switch to Front.
The automatic transfer switch in the coach should then Transfer the rear air conditioner to the 20 amp lead on the generator.
(This assumes a motor home, installed generator and automatic transfer switch)
You may also have to turn the 20 amp breaker on the generator itself back on.
โNov-09-2012 08:26 AM
โNov-09-2012 08:16 AM
Ponder
โNov-08-2012 06:32 PM
Ponder
โNov-08-2012 12:59 PM
bob_b wrote:
You are all making this too complicated with the Power Management stuff. The generator has two sets of power lines.
Line 1 goes to the big 30-amp outlet inside the storage area (where you plug in your 30-amp cord).
Line 2 goes directly to the back air conditioner. This is the line that many members here have modified.
Take the Line 2 from the generator and terminate it with a standard 15-amp outlet or the Female end of a cord.
Take the line that comes from the rear air conditioner and terminated it with a Male plug.
Now you can plug the rear A/C into the outlet for the generator OR plug it into an unused outlet at the campground electrical post.
You now have your 30-amp cord to the post which will run the front air and you will have a smaller 15-amp cord running to the post for your rear air.
Simple.
It took me a very hot August weekend in Las Vegas to motivate me enough to add the second cord;)
โNov-08-2012 12:30 PM
โNov-08-2012 11:56 AM
โNov-08-2012 06:44 AM
topflite51 wrote:
I am always surprised when someone states for a fact that you cannot run two AC's on a 30 amp system. My 98 Southwind does and does it well. Must be magic. On second thought, its the EMS.
โNov-08-2012 06:04 AM
