Jul-02-2013 02:18 PM
Jul-03-2013 07:17 PM
Jul-03-2013 06:00 PM
bluebirdPT36 wrote:Why should Harold run the test, he has nothing to prove. All those claiming that PSW is better than MSW, should do the funding for an independent lab to do the testing. Or is it just an old wives tale that PSW is better than MSW? I personally would like to know before I spent my MAD MONEY. 😛
Harold1946,
Why don't you buy a quality VOM, infrared therometer, a MSW and a PSW inverter and run the test? Prove that a MSW inverter is just as good and efficient(or better and more efficient) as a PSW inverter. Report back to us when you are finished with the test.
Jul-03-2013 12:15 PM
bluebirdPT36 wrote:
Harold1946,
Jul-03-2013 11:34 AM
Jul-03-2013 10:31 AM
Rich D. wrote:2oldman wrote:
If MSW works for you, great. A good PSW is much less risk. Not zero, less. I think it's only fair to people reading this that they're aware of that.
X2, exactly!
Harold1946, don't expect others to do your research for you. I find much testing and documentation on sites that support "off the grid" living. I'm sure you can find them too if you really want to. There is only one type of PURE sine wave inverter which almost exactly duplicates 120 VAC household power and then there are many types Modified square wave inverters. The better the MSW, the more steps it makes to approximate a pure sine wave thereby the fewer chances of over-heating, higher power consumption and reduced motor life. MSW inverters are NOT created equally.
And, of course (like the TV commercial with the young lady and the "French Model" date) just because it is on the internet does not make it true. 14 years is a long time in the world of electronics. If your setup worked for you all this time, great. It does not mean a new energy efficient refrigerator won't be harmed by a bad MSW inverter while costing more battery consumption at the same time.
Jul-03-2013 09:55 AM
Jul-03-2013 09:48 AM
Jul-03-2013 08:48 AM
Jul-03-2013 08:40 AM
Jul-03-2013 08:16 AM
harold1946 wrote:Rich D. wrote:harold1946 wrote:2oldman wrote:ScottG wrote:Seems strange economics to save a few bucks on an inverter and put who-knows-what at risk. But that's just me.
It's going to be better if you have a PSW inverter though and some are getting pretty cheap these days.
There is no proof that MSW does any harm to a compressor motor, only those that say it could, may, possibly, or some other form of conjecture.
This is our 14th year with a residential using MSW, and the second MH with the same set up. Previous coach was sold four years ago and the new owners are still using the same 14 year old Amana.
Seems to me it would be poor economics to purchase an inverter when one already exists.
It is not conjecture but fact that MSW inverters cause motors to draw more current, start harder, and have a shortened lifespan. There is much research on line posted by testing labs for "off the grid" equipment.
Remember that all MSW inverters are not created equally. Some have more "steps" to smooth out the square wave than others and those will not be as bad as the ones with fewer steps.
I would like to read some of the test results you refer to, but have not been able to locate any. Everything I find says refrigerator compressors suffer little or no adverse affects from MSW inverters.
Jul-03-2013 07:14 AM
Jul-03-2013 06:32 AM
Jul-02-2013 05:38 PM
Jul-02-2013 05:33 PM
Jul-02-2013 04:48 PM
