valve cover
81shastaboy
Hi just started it up the first this year when itso when it was warming up I smell oil it is on a 81 Ford e 350 with 460 how hard it to replace the valve gasket s
lets hit the road
4 REPLIES 4
spacedoutbob
Also, check the valve covers to make sure they are flat, if not lay it on the flat edge of a table and hammer it flat. That is a cause of leaks at times.
bob
Good Sam Club Life Member
OldRadios
Check to see if all the valve cover bolts are tight. I had an 85 that both valve covers leaked when I got it. After finding all the cover bolts loose and tightening them, no more leaks.
2006 Fleetwood 26Q
2010 Harley Softail Toad
2015 Ford Focus Toad
Upstate (the other) New York
MitchF150
Pull off the "Dog House" cover and see what access you have from there... In an E350, that's gonna be pretty much your only "easy" access.. ๐Ÿ˜‰
Then find the valve cover bolts and how easy they are to reach is how easy of a job it's gonna be... ๐Ÿ˜‰
Good luck!
Mitch
Home_Skillet
Not too bad, if you're mechanically inclined.
Might as well change the plug wires, as you will have to remove them.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
