vinyl flooring
STEVEP220
I plan to install adhesive backed vinyl flooring in my M/H. I want to use a good quality flooring that has a wood look to it. I would like to know what brand you recommend and do you think it will go over excessing vinyl flooring in kitchen and bath without removing old vinyl?
4 REPLIES 4
Playtime_II
I used the allure planks (and have 8 cases left as we decided not to pull up the tile in the kitchen and baths). If you are near Gainesville I can show you the results (2 planks "shrunk" leaving a gap but that was my install error). I also did the vertical stairway and sliding cover.
Playtime IV
2006 HR Scepter 42DSQ
deadbat
STEVEP220 wrote:
I'm sorry I plan to use vinyl plank flooring.
best thing to do is resheet all your floor area u want to cover and then use the authentic vinyl planking that you glue down.I have done a couple units this way.looks very nice and better job,although way more work between new sheeting and spreading glue etc
STEVEP220
BuckBarker
Armstrong still makes excellent sheet vinyl. The problem with installing over the existing cheaply made vinyl is the cheap stuff tends to split. The splitting would ruin your new flooring.
