My Washer Dryer breaker wont stay on. I keeps tripping after re set in about seven seconds, makes no difference weather the washer is plugged in or not.
if you have a splendid, might be between cycles, hold the start button an the slow spin, same time, ALL Lights will flash, see if that clears out your problem
"2012 Forest River 360 DS" "Ford V-10" "2013 Toyota Corolla on Tow Dolly"
You have a short inside the junction box where you plug the washer in. Open the box with the BREAKER OFF, and check the wiring. Chances are one of the wires has come loose. Check for burnt areas around the receptacle. Replace if necessary. A regular household duplex plug from Home Depot will work.....Don't forget to turn the breaker back on after replacing/repairing the plug.....Dennis
We can do more than we think we can, but most do less than we think we do Dennis and Debi Fourteen Years Full Timing Monaco Executive M-45PBQ Quad Slide 525HP Cummins ISM 6 Spd Allison 2014 Chevrolet Equinox LTZ W/ ReadyBrute CLICK HERE TO VIEW OUR TRAVEL BLOG
