Ok I like that first response
๐Atwood the water heater tank is surrounded in styrofoam insulation. If you acces what I call the "Back" (where the pipes connecct) you will see a black box.. With a Romex cable attached to it or to be more precise entering it.
Just above the box under a insulantion panel that might or might not be removable easily is the element. Standard element you can get at Lowes, Home Depot, Mennards Et-al
When I replaced my tank I changed the new element that came with it for a 1500 watt 240 volt element. This gives me about 375 Watts of water heater.. Takes 4 times as long to make hot. (but not a problem for me living alone) but since then (over a year ago) I've only tripped a 30 amp park-side breaker twice... This week.. Weak breaker on this site plus I have an A/C that's misbehaving it is what it tripping the breaker (last trip the water heater was OFF when it happened).. At 1500 Watts I'd not be able to use electric heat.
