Water stains
pappaone
I have searched but unable to find answer.. is there any way to remove or clean up water stains in fabric like ceiling?? had a leak around sky light over shower. have resealed but would like to take care of the stain
Thank you
Rich & Jennie(mate of 59 yrs 6/6/59)
2017 Minnie Winnie 27Q
1 Grey Persian cat
1 German Shepard/Blue healer pup
6 REPLIES 6
Jagtech
A dilute solution of vinegar and water in a spray botle, spray it on and suck it off with a wet vacuum before it dries. Works like a charm!
1998 Triple E F53
1995 Jeep Wrangler toad
GrampaR123
Spot Shot for carpets in a spray can works great for water stained carpet type ceilings. Available at Home Depot and most super markets.
Good luck.
gbopp
donkeydew wrote:
oxi magic from lowes will do the trick, spray it on and blot it. it will disappear almost before your eyes
Thanks, I've never heard of it but, I'll give it a try. I have a couple spots.
cvbdsl
Oxi-clean. Mix it in a spray bottle and soak the area and then blot. Instead of blotting it up I used the furniture attachment on a carpet cleaner to suck up the Oxi clean. I then rinsed with hot water from the attachment and sucked it all up again.
Make sure you do not leave it or make it too wet.
Do this three of four times and let dry. If it still shows repeat.
It worked wonders on a previous MH where the roof seams had been neglected by the PO. I was able to get several thousand $ off the asking price and had it cleaned in a week. None of my friends/family could tell. Also had the roof re-sealed with enternabond and the AC seals replaced.
Unfortunately the shop that did the AC seals did not tighten them down enough and I ended up with another stain - same process worked again.
I have before and after pics somewhere.
HTH
P.S. Cover your furniture/seats when spraying - oxi clean turns white when dry!
2008 Holiday Rambler Scepter 42 PDQ
2018 Ford Edge SEL- Ready Brute Elite Tow Bar/Blue Ox Base plate/Patriot Brake System
Retired Canadian Army WO (1971-2000)
donkeydew
2oldman
Ceiling stain April 2015
