wet generator
san_elijo_kb
a couple weeks back we were driving through some pretty heavy rains in so cal. when we got to our destination ,still raining , generator would not stay running . holding start button down would keep engine running ,letting go engine would stop. tried a couple times the next day. same thing . returned home and a couple days later started right up. what got wet or what dried out to cause this. thanks kb
Ken and Mary Ann
4 REPLIES 4
Two_Jayhawks
Similar situation happened to me a couple years ago on our spring trip to New Orleans. We drove through some horrible storms and the driving rain literally stopped the already running genny. We checked into out CG and enjoyed the week in NOLA. Departure day it fired up like always and had worked fine since.
Bill & Kelli
2015 DSDP 4366 pulling a 21 JL Unlimited Sport
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
wny_pat1
What Spizzer said. And your lucky it did not get Hydrolocked!
“All journeys have secret destinations of which the traveler is unaware.”
Spizzer
Not sure where yours is located, but on my DP, the air intake and filter seem like they could get wet pretty easy under the right conditions. If the air filter were soaked, the gen may not get enough air to run without the help of the starter....just a thought and something really to check.
Jeff
Jeff
Retired AF, retired contractor, really retired!
2007 Winnebago Journey 34H 350hp Cat
2005 Jeep Grand Cherokee Toad with Air Force One
Dale_Traveling
Any number of potential sources could have cause the problem. Water in the connector from the inside start/stop switch, governor, run sensor, oil pressure sensor,,,,. Since it now works without a crystal ball no way of knowing.
2006 Hurricane 31D built on a 2006 Ford F53
