โAug-17-2015 08:53 AM
โAug-19-2015 03:31 PM
โAug-19-2015 03:24 PM
โAug-19-2015 06:25 AM
โAug-19-2015 04:54 AM
Bill.Satellite wrote:
Has this antenna worked well in this location in the past and is not working properly now or is this a new location? If you can go up on the roof with a multi-meter you want to disconnect the coax from the Batwing head and check the coax. You should find that the center conductor is showing at least 12VDC. If not you will want to verify that you have the power to the antenna turned on inside the coach (wall plate with a tiny (usually green) light. If that's all good you will want to bring in another recent digital TV and connect directly to ensure it's not something having to do with the TV or other cabling issues.
โAug-17-2015 03:34 PM
TC&Z wrote:rgatijnet1 wrote:
If you have been having signal problems with an antenna that was previously working fine, I would say that your problem is with the coax cable or the connections on either end. Antennas do not wear out but the cable connections do. They let in moisture which eventually causes corrosion. To install a new antenna, without correcting the cable problems, is just a waste of money.
Very interesting information, much appreciated, (I posted this inquiry) perhaps it is not my antenna at all but something else. Here is my symptom, we will have been watching a show fine and then it just dies entirely, goes to black screen "LOST SIGNAL". We wait several minutes and no recovery. Yet when we change channels other channels work ok. Change back still dead. It is not poor signal with pixelated lines. We occasionally have this symptom and I rotate the antenna to tune slightly and it improves, or I determine that is the best it can be. Any ideas what to check?
โAug-17-2015 02:17 PM
โAug-17-2015 02:14 PM
โAug-17-2015 01:49 PM
TC&Z wrote:Depends on where you are located and local weather patterns. Inversation layers moving around can greatly affect receiption and will exhibit exactly what you are talking about. Just because it happens on one channel and not others doesn't mean much unless you are familiar with with the various transmitter locations and radiation patterns of all. About the only thing you can do locally when this happens is to look at the signal strength of the problem station and see if it's dipped below acceptable levels (obviously it has) , but if there is an inversion involved you will often see the signal floating around a view bars one way or the other, OR it could simply appear or disappear when the sun goes down..rgatijnet1 wrote:
โAug-17-2015 01:37 PM
โAug-17-2015 01:34 PM
โAug-17-2015 01:06 PM
Ed_Gee wrote:
Having followed innumerable discussions on RV TV antennas, it is my opinion that the 'best' antenna is the old reliable Bat Wing, which you already have. Adding the Winegard Wingman will improve its stock performance noticeably, but unless you have something wrong with it ( like the RF pre-amplifier in the head has failed or power to the pre-amp is not present ) you probably won't get any better performance from the newer choices.
โAug-17-2015 12:50 PM
โAug-17-2015 12:49 PM
โAug-17-2015 12:42 PM
