What transmission do I have?
Geocritter
I recently purchased a 1994 33' Holiday Rambler. I know that it has a FI 460 V8 gasoline engine, that it has a 5.13 rear axle, and that it's built on a Ford F Super Duty chassis (though I thought it had a F53 chassis, very mysterious). Now I'm wondering who made the automatic transmission. From what I understand after reading Fords inadequate owners manual is that it's a 3 speed + OD and that Ford recommend using Mercron automatic transmission fluid. The reason I'm asking is that I'm a believer in synthetic lubricating fluids and preventive maintenance. That being the case I'd like to change out the AT fluid for a high quality synthetic.
Steve
13 REPLIES 13
FuelFunnel
RLS7201 wrote:
All F53s 1988 to 1997 were equipped with an E4OD transmission. The transmission case is designed for 4WD and uses the deep pan and long transmission filter tube. A ZF emergency brake is bolted to the flange where a transfer case in normally installed on 4WDs.
It has very slow, soft shifts and it's service life can be extended with a Banks Transcommander.
Richard
I do not have the deep pan on my 1991, so you will need to determine which pan you have when you get a new filter.
Kris
Geocritter
I want to thank everyone, the bits and pieces of information are really helpful. Such as with Nick-B's post I now know that with a torque converter drain plug I don't have to take my RV into a oil change facility to change out the AT fluid. I will also look into that second transmission cooler. Back in 1990 my non-mechanical brother took a 10,000 mile RV trip in a second-hand Class C RV that had no transmission cooler at all. Needless to say, half-ways through the trip he had to replace his transmission. I don't care when the RV was built, the cheapskate manufacturer should be flogged for leaving off such an important piece of equipment.
Steve
Nick-B
Ford actually updated the fluid recommendation to use Mercon V (five) which is a synth blend. Adding a second trans cooler is recommended especially if you will be towing and / or in the mountains.
FYI, you should have a drain plug on the torque converter. Pull the rubber plug on the bottom of the bell housing and turn the engine until the drain plug appears at the access hole.
Nick
1995 Coachmen Santara MB360 w/slide
F53/460 chassis w/tag
WILDEBILL308
427435 wrote:
mnoeltne wrote:
If you're looking for a good quality synthetic fluid for it, Mobil 1 Synthetic ATF is fully Mercon compatible and is readily available all over the country.
x2
x3
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
wa8yxm
Find a ford truck vin translator.
Feed it the vin
The transmission model is encoded therein, the translators should be able to pick it out .. .At one time about a decade or more ago I could have done it for you, in some cases by inspection, in others by the book. I used to have the book.
Jarlaxle
Also: I suggest a trans temp gauge and a GIGANTIC cooler!
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. ๐Ÿ˜ž
Current rig:
1992 International Genesis school bus conversion
427435
x2
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
mnoeltne
Mark & Joyce Noeltner
2005 Fleetwood Fiesta 26Y
2001 Jeep Cherokee Sport
RLS7201
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Geocritter
phillyg wrote:
Sounds like an E40D to me, too.
I think you're right, is that known as a reliable transmission, or are there some quirks I should know about?
Steve
phillyg
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Subyguy
If the OD button is on the end of the shift lever it is a e4OD tranny and will take dextron 3 I would stick with motorcraft fluid You don't see many rigs built on that chassis
fischer
I think ford has a dex/merc synthetic fluid you can use.
2016 Winnebago 35B v10
2006 Jeep Liberty 4x4
Blue ox Tow Bar
