Wheelbase ratio
winnehonda
what is the best wheelbase to overall length to give a good ride? Thanks.
Mark Hanlon
8 REPLIES 8
rgatijnet1
Tag adds stability as does a toad behind your coach.
JetAonly
Tag adds stability.
2000 Monaco Dynasty
ISC350
Effy
Can I assume (bad I know) that a unit with a tag throws some of this out the window? I think from stability a tag is the best right?
2013 ACE 29.2
rgatijnet1
The loading of the coach has more to do with the handling than the wheelbase. With a long wheelbase, if the front end is loaded light, the coach will wander. With a short wheelbase, with the front end loaded close to the maximum axle weight, the coach will handle fine.
JetAonly
Also depends on where the weight is, motor in front vs motor in back.
2000 Monaco Dynasty
ISC350
DeWat
The one I've seen the most is 53%, but I have also seen some that say 50%. Then there are those who will say that the whole length to wheelbase ratio is a myth, but personally I choose to go by 53%. If you look at the second question under the FAQs at Henderson's Line-Up, a pretty good authority in steering and suspension, you will see that while they don't give a specific ratio, they do talk about shorter wheelbases being a contributing factor to porpoising.
Dewey & Sharon
Southern Maryland suburbs of DC
2014 Tiffin Phaeton 40QBH
winnehonda
Thanks.
Mark Hanlon
Road_Dog
55% or better!
