โMar-13-2015 01:30 PM
โMar-14-2015 07:49 PM
eric99 wrote:tatest wrote:
Start here: Speciality Hitches at E-Trailer.
What fits will likely be a Class V weld-on, so partially a fabrication. Not likely exactly 10K, but something in the 10K to 18K range.
Might be $120 to $300 for the hitch parts (essentially wholesale online) for a Class V under 20K rating and a couple hours labor for fitting and installation. If the installing shop buys the hitch assembly you might be charged retail, $300 to $500.
If you go 20K rating or higher, the hitch itself might be $600-800 wholesale, over $1,000 retail, plus installation.
Thanks. Etrailer only carry up to 5k. I'm still looking
โMar-14-2015 04:49 PM
eric99 wrote:
for a 2007 Sportscoach Elite 40QSL?
Or, where one can be fabricated?
How much would a 10K hitch cost or the cost to fabricate one?
Thanks for all of your help!
โMar-14-2015 01:30 PM
โMar-13-2015 05:08 PM
Ivylog wrote:
It would help if we knew what's over 5K that you want to tow. If it's a large vehicle that you are going to tow four down you do not need a new hitch. A simple V brace from the receiver to the MH rails is all you need as you do not have any tongue weight. If it's a heavy trailer with more than 500 lbs of tongue weight then a H looking brace may be all that's needed added to your current hitch. Any good welding shop should be able to solve your problem once you tell them what you are trying to do that exceeds the current 5K hitch.
โMar-13-2015 02:48 PM
โMar-13-2015 02:27 PM
โMar-13-2015 02:22 PM
โMar-13-2015 02:11 PM
โMar-13-2015 01:48 PM
