โOct-29-2023 06:02 AM
โOct-29-2023 04:48 PM
โOct-29-2023 04:45 PM
โOct-29-2023 04:43 PM
โOct-29-2023 03:45 PM
Campinfan wrote:
The reason why I say four of either is because I would have room for 4. That is why I have the question of 4 12 volts which would give me 4 times the amps of one....
โOct-29-2023 02:56 PM
Campinfan wrote:
The reason why I say four of either is because I would have room for 4. That is why I have the question of 4 12 volts which would give me 4 times the amps of one....or 4 6 volts which would effectively give me 2 12 volts. I hope that clears it up. If all things were even....I would have 4 x 12 volts @100 minutes a piece (just pretending here) so that would give me 400. If each 6 volt was 100, I would only have 200 because I know in series only the volts double not the amps but then they would be partially in series so then I would have the equivalent of 2 12 volt batteries @ 100 a piece for a total of 200. So it seems the 12 volt battery is a better idea until I think about how much lower you can drain the 6 volts.
โOct-29-2023 02:22 PM
โOct-29-2023 02:06 PM
โOct-29-2023 01:56 PM
โOct-29-2023 11:51 AM
Campinfan wrote:
I am trying to learn more about 6 volts batteries versus 12 volts. I know the 6 volts can be drained further and recharged more (better lifetime). At least that is what I think is true. But it seems 12 volts have more amp hours (or minutes) (I think). So if I got 4 batteries, would you get 4 12 volts and put them parallel or 4 6 volts and wire them in series to get 12 volts and then in parallel to double the amp time? And why? I may be venturing into the Motorhome world and I have many questions.
Thank you.
โOct-29-2023 10:12 AM
โOct-29-2023 08:46 AM
โOct-29-2023 08:07 AM
โOct-29-2023 06:17 AM
