windsheild wipers erratic operation
traveylin
My Georgetown 2011 ford f 53 chassis has started giving an erratic operation on the windshield wipers. They will not turn off without turning the engine off. The intermittent operation will not work. It does work at high setting but again needs to have the engine off to stop. and it frequently does not return to home.
If any one has have a referral to a repair source of info it would be appreciated.
thanks pops
2 REPLIES 2
wilanddij
Been driving in the rain? Check for wet cable connectors behind the grill. Unplug, dry them out and test. If that fixes anything, figure out how to keep them dry.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Ford C-Max/Blue Ox
"We have met the enemy, and he is us" Pogo
MountainAir05
Two things , the switch inside needs cleaning or the motor park system is the issue.
http://www.fordf150.net/howto/fix-intermittent-wiper-problem.php
