Our dog decided to protect our motorhome from critters and tore up this area behind the front passenger tire. I have no problem repairing the wiring, but I am curious to what this wiring goes to or what function it serves. Any ideas? Everything seems to be working ok... Thanks in advance... Russell
Russ
2006 Gulf Stream B Touring Cruiser Series M-5270-Ford E-450 6.0 Turbo Diesel
Curious, is that what looks to be plastic wire loom wrapped with copper braid and aluminum foil? Seems like chassis wiring versus anything to do with the RV side
One broken wire up by that brake hose or whatever that rubber to metal hose is.
You are not looking at the problem correctly. See the copper wire splayed out. If you look closely at the picture, it used to have insulation on it and it connected to the wire at the top right that appears to be cut. It is 14 gage wire almost like a lamp cord..
Russ
This looks like it might be heavier gauge than your typical vehicle accessory wiring, so I might venture to guess it could possibly be part of the battery combiner circuitry to charge the house battery from the engine.
It's not too surprising that it seems to be working since the conductors are still continuous. Shorting out could be a definite possibility.
