Wobbly Table Leg
lucytravel12
Our table leg doesn't fit well in the floor socket, so the table wobbles. We have the leg from our old camper table, and it doesn't fit well either so we presume it's the hole in the floor that's the issue. It appears that the hole is too deep for the crimped part of the leg. Putting a shim in doesn't help at all. Anyone else have this issue?
2004 Pleasure-Way Plateau TD
1987 Intervec Falcon
"Rockin" Retirement
2 REPLIES 2
LadyRVer
I wrapped tape around the bottom of the leg before inserting it in the metal holder. Worked for me in the Pleasure Way.
Artum_Snowbird
Do you have a wall that goes to the floor under the table top? If so, the best modification ever is to install a Dream Dinette for your table top.
I put one into a previous camper by using my studfinder and mounting a plate on the wall for the slide to go up and down on.
But, single post tables are notorious for wobbling.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
