workhorse 2004 8.1 help please...Radiator hoses...
johncasey37
Realized after my 2004 Southwind / Workhorse threw a Serp-Belt. that I had better replace the typical Maintenance items. FYI, your repair contract does not cover maintenance items. Anyway, i was successful at getting the right tensioner and idler pully, belt. But the Radiator hoses, upper, lower, bypass are proving very difficult. Been all over the internet for hours.
Old hoses have the following numbers on them, which are NO help, so far:
Both say Made in USA.
Lower : 3C24 EBP D1 80MH44 XBS 1305 LS
Upper: 3B28 EBP D1 80MH25 XBS
These are not right for my RV,too short by 5 inches
GM W0000218
GM W0000219
GATES 23803
CARQUEST 23803
NAPA 16487
ACDelco 22707L
GOODYEAR 61667
i plan to visit the RV repair place if i cannot find them online.
Thanks.
11 REPLIES 11
allbrandauto
WHAT PART NUMBERS DID YOU USE
johncasey37
Thanks, Yes, i got the 218 and 219 today, still 2" shorter than what came off, but old ones were probably stretch over 11 years. The confusing part was the cross reference of 218/219....none seem to be the same. Got all the parts on the way, hardest one is the bypass hose, will go to NAPA tomorrow for that. There was a couple places to order it, but need it quick, got to plan the next vacation to Gulf Shores,Ala. Changing the water pump also, current one makes noise just moving the fan blades.
Surprised me how difficult it has been to track down the right stuff....whew....
Yes, and Thermostat....took a shot at ordering one.
Thanks for your help.
ArchHoagland
Are you replacing the thermostat too?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
catkins
Make sure the hoses are long enough. Friends had issues with hose just a "bit" too short.
falconbrother
Pull the hoses and take them to NAPA. Most of the time the wearhouse up the street can figure it out. The other times I went to Advance and they figured it out.
wilanddij
Just about all you want to know about WH parts here OEMY's
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Ford C-Max/Blue Ox
"We have met the enemy, and he is us" Pogo
Carvin_Marvin
Have you tried IRV2 forum? For the w22 they show NAPA 8441 upper Napa 9058 lower. I didn't see in your post which workhorse you have.
rgatijnet1
Go to this website. It is the best place to locate WH parts: Radiator hoses
1492
Moderator
Moderator
Moved from Forum Technical Support
darsben
GO TO A NAPA WITH A DEDICATED truck counter not the local rinky dink NAPA where the clerk has no clue about trucks.
You may have to go to Atlanta
Traveling with my best friend my wife!
rvten
Check your local GM dealer. This engine is used in trucks also.
NAPA or other parts store should be able to get them
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
