Have you tried 91 octane fuel? While it might seem more expensive, I did find I got more than 10% better mileage, so the extra $0.20 per gallon gave me more miles per $100 in fuel!
It might also be a knock sensor that is picking up pinging, and is setting back the timing, and increasing fuel usage to compensate for pinging that is not really there. Higher octane fuel will improve mileage by changing the timing to more advanced, (this can cause pinging on 87 octane fuel, but will not on 91 octane fuel, so you will make more power per gallon by leaning out the fuel and changing the timing. Your 'Box;' probably is set up to save fuel - but only when running 91 octane.
Because your 80 gallon tank is good for about 500 miles at 6 MPG, you will need to take a couple of long trips, then start filling with 91 octane (about 20 gallons at a time), use as much as you can before filling up again, to have a higher percentage of 91 fuel, and then the knock sensor should respond well to the higher octane fuel.
So if you get down to 1/8 tank, you probably will still have between 10 and 20 gallons in the tank. Adding 20 gallons will bring up the average octane to about 89. Use a lot of that fuel, and add 20 - 40 gallons of 91 and your average will be close to 90, and you should see a improvement after the next tank fill.
Good luck!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline waterEscapees.com
