โNov-21-2008 07:43 PM
Congress has changed the date to June 12, 2009. About 1/3 of the television stations have applied to the FCC for permission to go ahead with the transition on February 17. Although the FCC chairman has stated that they will not let all stations in a given market terminate their analog broadcasts, it is very likely that many stations will be broadcasting only digital signals after February 17.
Digital and High Definition are not equivalent terms. All High Definition signals are Digital. But not all Digital signals are High Definition. The mandated changeover is to Digital, not to High Definition.
Added 1/25: The following notice is on the government coupon site:
Important: The TV Converter Box Coupon Program has reached its funding ceiling. However, coupon requests from eligible households will be filled as funds from expiring coupons become available. If you would like to apply for a coupon today and are eligible, you will be placed on a waiting list and will receive coupons an a first-come-first-served basis as funds from expiring coupons become available. Coupons will expire within 90 days or the date they are mailed
Note: Apparently, there is a great temptation to connect the converted box to the cable leading directly from the antenna. In most cases, not only will this not work it could damage the converter box. This cable carries power to the built-in amplifier.
โApr-02-2010 03:01 PM
tplife wrote:Huh?tazmangk wrote:
just wondered if anyone knows if they make a 12 volt digital tv?..I camp out in the woods at times and still would like to catch the news, weather etc without the noise of a gen set.
Good luck, digital transmission distances are rated at 20 miles max from the transmitter, and that's with a good-sized antenna. It's not like analog VHF.
โApr-02-2010 02:54 PM
โDec-25-2009 09:33 AM
โDec-24-2009 10:08 PM
hotrod4x5 wrote:Some folks with this problem have managed to flip the antenna 180 degrees on the mast. Any chance of that?
The problem I have with the wingman is that when my antenna is stowed, a vent would be impacted by the wingman. The batwing works pretty well for digital without it, but I am sure the wingman helps, I just wish I could mount it on mine.
โDec-24-2009 06:15 AM
โDec-23-2009 11:28 PM
jwill5046@aol wrote:People that don't understand RF shouldn't render opinions... Oh well. If you don't have one already, add a Wingman to the antenna. It will really help the UHF.
Pulsar, Thanks for the post, I had questions about the bat wing and was told it wouldn't work for the digital. I tried it out yesterday and it works great. Thanks again for the info. Jerry
โDec-23-2009 08:01 AM
โOct-18-2009 11:30 AM
โOct-18-2009 11:17 AM
โOct-05-2009 07:36 AM
โOct-03-2009 11:14 AM
Homer wrote:It is entirely possible that you are "too" close (if it's not one thing it's another). I have noticed the same thing when camping at our favorite spot on the beach that I actually get better reception when the amp is off since there is a major radio site 2-3 miles away overloading the pre-amp. If I'm careful I can null out the offending site with the batwing, but I get the same results just killing the amp.
I have no distribution box, (here we go again), I hooked the converter to the exterior center jack on the power supply,(per instructions from Cust Serv Winnebago. I have the wingman installed. I can get 4 digital channels relatively near by, nice and clear, as long as I do not turn the amplifier on. Turn it on and the screen turns full snow. I also have the RCA F cables hooked to the converter. I am sure I am hooked up incorrectly, but I swear I have tried every conceivable process. Any one have any suggestions. I also use satellite TV remote dish, no problem with it at all. It would be a major undertaking to take the TV out to get to the back of it. Can anything be worked out with the power supply cabling? I am about to give it all up. PM's are welcome
โOct-01-2009 06:49 PM
โAug-16-2009 09:10 PM
โAug-16-2009 05:43 PM
โJul-29-2009 04:28 PM
