โOct-18-2014 05:08 AM
โOct-24-2014 04:41 PM
โOct-24-2014 05:34 AM
โOct-23-2014 04:37 AM
Bill.Satellite wrote:
The biggest difference between AT&T and Sprint and the Verizon service is not the coverage but what happens when you have to roam. AT&T and Sprint limit roaming data to about 300MB/month (you know, nothing!) and Verizon does not have any similar roaming limitation.
โOct-22-2014 06:03 PM
โOct-22-2014 04:17 PM
โOct-19-2014 10:35 AM
โOct-19-2014 09:45 AM
โOct-19-2014 05:40 AM
โOct-18-2014 11:34 PM
jcpainter wrote:
Do your due diligence with AT&T. We traveled out west with another couple last summer. They had a 6GB AT&T plan and we had Verizon.
Their data service was shut down after minimal usage. They called AT&T to see what was going on and they were told to read the fine print in their contract. Apparently when you are in an area where AT&T does not have their own towers, but provides service by using agreements with local companies, they limit your data usage to some really small amount and shut your service down if you go over it. I don't remember the number, but I believe it was less than 1 mg!
I immediately called Verizon to see if they also did that and they told me that they were familiar with the AT&T policy, but Verizon did not do the same.
That was over a year ago, so things could have changed . . . but you might want to check it out before you make your decision.
โOct-18-2014 12:09 PM
โOct-18-2014 10:50 AM
โOct-18-2014 10:07 AM
โOct-18-2014 09:53 AM
โOct-18-2014 09:06 AM
