โApr-25-2016 07:02 PM
โApr-27-2016 11:06 AM
โApr-27-2016 05:37 AM
srt20 wrote:
Turning off the booster results in getting no signal at all.
โApr-26-2016 05:18 PM
Sam Spade wrote:srt20 wrote:
I was able to get one channel, and 2 sub channels, but they would break up a lot and it wasn't really watchable.
Thanks!
Did you do the test that I suggested, turning the amp off ?
If the channels you want to get are all in the same general direction, you probably won't have to turn the antenna at all.
And you should be able to mount an RV antenna on a stationary pole instead of the top of the RV. That way you could "convert" it to real RV use later if you want.
โApr-26-2016 03:46 PM
Thanks!
โApr-26-2016 12:05 PM
JiminDenver wrote:
Your rig may be new but there are still things to check. The end connection on the cable coming down from the antenna was so poorly installed that it nearly fell off when I got into the outlet box.
There are no OTA signals where we camp so we use a pay as you go portable satellite system.
โApr-26-2016 11:48 AM
โApr-26-2016 11:26 AM
Ed_Gee wrote:
Original poster has received lots of good information ... and I agree, assuming his stock Omni antenna is working properly, his best choice would be to have a Winegard batwing antenna installed. However, if he does not want to put the required hole in his ceiling, a lot of RVers are having very good results with the Winegard Razar Automatic antenna .... but it is expensive.
โApr-26-2016 11:24 AM
โApr-26-2016 10:52 AM
โApr-26-2016 09:10 AM
โApr-26-2016 08:08 AM
โApr-26-2016 07:43 AM
โApr-26-2016 06:07 AM
โApr-26-2016 06:06 AM
JiminDenver wrote:
The best out there? A full sized house antenna like years gone by. Those will pull in more than any of the cute so called HDTV antennas out there.
