โJan-29-2022 02:22 PM
โFeb-03-2022 06:50 PM
โFeb-02-2022 04:46 PM
โJan-31-2022 11:46 AM
โJan-30-2022 07:05 PM
โJan-30-2022 06:03 PM
Dutch_12078 wrote:Gulfcoast wrote:Dutch_12078 wrote:
As Jon said, a MIMO (Multiple In Multiple Out) antenna set is a good choice if your hotspot or router supports it. I use an aimable dual Yagi set that has equaled or out performed our previous $600 amplifier/repeater everywhere we've been with it at less than one-third the cost. My set is mounted just above our Winegard "batwing" TV antenna.
Hey Dutch.... could you please post a picture of the rear of your batwing antenna? I have my yagi's, just need to see the best way to build a bracket for them. I have to build a bracket that will allow the antenna to go up and down, but I haven't worked that out yet. Thanks
Here's a couple of shots of the back and the roughed out bracket. The red arrows on the antennas were just temporary to indicate the top so a condensation vent was at the bottom. The bracket was cut from a piece of 1/4" thick scrap aluminum. The two larger holes were already in the scrap piece, and were not used. The antenna mounts themselves are just the 'L' brackets that came with the antennas hammered flat. The antennas maintain the same orientation when lowered the same as the batwing.
โJan-30-2022 05:19 PM
โJan-30-2022 05:14 PM
โJan-30-2022 04:54 PM
Thank you!
What type of router are you using?
โJan-30-2022 03:26 PM
crasster wrote:
I'm having a lot of trouble traveling because I can't get a "decent" connection. I must have one for part time work.
Decent means 10mbps . . .
3) How is starlink?
crasster wrote:
4) How is any other satellite internet?
โJan-30-2022 02:45 PM
Gdetrailer wrote:Thermoguy wrote:
Is FMCA just a Sprint mobile internet plan? How does it work if you have a poor cell signal or no cell signal? Seems like it would be the same as any cell service - is this incorrect?
I have a Verizon jet pack and when I get to about 1-2 bars, it is worthless. Won't load anything on my devices.
Starlink will be the solution, but it's still a couple years off. Not sure how the cost of expensive hardware and $100 a month will make it worth it.
Sometimes it's nice to just check out of technology.
Yes.
FMCA is nothing more than a reseller of Sprint.
There are only three real cellphone OEMs, Verizon, ATT and Sprint. Every one else is nothing more the resellers, buying services from one of the big three.
It is possible to have one or more of the big three OEMs close enough to you to work for any of the big three OEMs or only one close OEM enough to work but you are not on that specific OEM network and you have no signal.
Not all three OEMs have good coverage in all areas and you need to do your homework to figure out which of the big three OEMs have a tower closest to where you are planning to camp.. Unless of course you subscribe to multiple OEMs services..
In my area home, ATT has more towers (three within 3 miles) close to me, Verizon has one (two miles from me) and Sprint has zero (IE zero service, Sprint in fact has only one tower in my entire county which happens to be near a Interstate far, far from me)..
Sprint and Verizon tend to have more towers near larger Metro areas, ATT seems to have a bit more coverage in rural areas like I am in.
With 5G rollout and 3G networks going dark soon, everyone will be relying on 4G LTE networks even heavier changing the coverage landscape. 5G does not go as far and requires more towers making it a lot more costlier to roll out to rural areas so your are most likely only going to see true 5G close to big metro areas.
There are cell tower maps you can search the internet for which can show the concentration of cell towers for each OEM carrier and the coverage of those towers instead of guessing.
โJan-30-2022 02:33 PM
โJan-30-2022 01:34 PM
โJan-30-2022 11:29 AM
โJan-30-2022 10:47 AM
