Cable
Jaaderow
We just moved to a new location yesterday, from another ground where both tvs worked. The bedroom tv found all of the channels but the living room tv is not. Help! It was set to cable previously and is now.
3 REPLIES 3
1492
Moderator
Moderator
Moved from Forum Technical Support
RoyB
Make sure the small led light is OFF on the Antenna Wall Panel. This is only ON when you are using the OTA Antenna. This switch supplies 12VDC up to the OTA Antenna Pre-amplifier mounted in its base...
Also sometimes I have to scan for channels again from the TV MENU if I turn off my HDTV...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
1971duster340
Did the antenna amplifier get turned on?
Greg
N5LFH
2007 Chariot
