โFeb-25-2014 09:49 AM
โOct-09-2014 05:17 AM
Woodtroll wrote:
Hello, friends!
Based on a lot of reading here and elsewhere, I have decided to invest in a cell phone signal booster and a Wifi amplifier. We won't need these often, but we do stay in several places where they would come in handy. Since I won't use them all the time I've decided against a permanent antenna installation, but would rather mount both antennas on the same, temporary mast that I could set up as needed. If I use a cell booster antenna such as the omni-directional Wilson trucker-type or something similar on the top of the pole, then use a flat panel directional antenna below that for the Wifi, I figured I could set up the mast, point the directional Wifi antenna in the direction of the campground Wifi, and be all set.
Do any of you folks who understand the magic of electronics know of any idea why this would not work? If it matters, the cell booster is the Cyfre CA-819, and the Wifi booster is the Alfa AWUS036NHA.
Thanks very much!
Regan
โAug-06-2014 08:10 PM
paulsang wrote:Maxi Signal wrote:pamngreg wrote:Maxi Signal wrote:pamngreg wrote:
Has anyone tried the Smoothtalker Mobilex1 that was highlighted in the most recent issue of Trailer Life? I was wondering how it would compare to the Wilson model. We have 4G through Verizon, need to get signal in the mounntains in Southern Colorado and NM. Thank you for any inforamtion.
That unit is only dual band ( 850 & 1900 mhz ) and will not do anything for 4G frequencies . 700 , 1700 and 2100 mhz
Recommendations? How about the new Wilson DB Pro???
Best recommendation - Wait ! There will be lots of options later this year when FCC gets all new units passed . You would be doing your service to make a purchase right now . There will be more options and better quality stuff available in the near future.
Any clue on a time frame? I am super curious.
โAug-06-2014 08:02 PM
โJun-19-2014 04:25 PM
โJun-19-2014 03:39 PM
โJun-16-2014 02:21 PM
โJun-16-2014 01:50 PM
โFeb-27-2014 12:21 PM
โFeb-27-2014 11:36 AM
โFeb-26-2014 07:26 AM
โFeb-26-2014 02:09 AM
โFeb-25-2014 10:57 AM
โFeb-25-2014 10:16 AM
