Change to wifi in motion from tv satellite
bigred1cav
I am requesting information on the wifi in motion connections such as singlepoint wifi in motion? I now have direct tv and am not happy.
My questions are how well does the wifi receive in remote areas? Is is dependent upon local wifi or is it connected to the mystery wifi god in the sky?
If I am in Montana 150 miles from closets town will I be able to receive wifi? Does wifi rely upon cell phone service in an area?
I may have additional questions for those of you in the know. I am particularly interested in those of you with real wifi experience. It is not a cheap venture to go from sat to wifi.
Thank you
25 REPLIES 25
CA_Traveler
What's your problem with DTV?
2014 Grand Cherokee Overland
Bob
STBRetired
Have unlimited data package so not worried about how much data I use. Mostly we use DirecTV but will stream when dish is blocked. Good tip on the resolution though. That data usage was for 1080P in living room and 720P in bedroom.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
GordonThree
STBRetired wrote:
Just as an example, we were in Pigeon Forge under some trees so no satellite. We burned 27GB in data for 6 days of streaming our evening entertainment.
Depending on the size of your RV television, set your streaming resolution as low as it'll go. 32 inch and under, 480p looks the same as 1080p. 50 inch and under, 720p looks the same as 1080p... but the data savings is drastic, also buffering in fringe areas is reduced.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
GordonThree
2oldman wrote:
You will be happier with DTV than wifi in remote areas.
yup!
unlimited streaming of 100s of digital tv and music channels with no data caps.
STBRetired
2oldman
It's too high.
shastagary
the amount of data needed to stream tv is just to high to use these services. this may answer some of your questions. wifi-in-motion
Moderator
Moderator
Moderator
Moved from Lifestyle
Tom_M1
A WiFi hotspot just gives you access to the internet. You can stream TV programming and movies on the internet, but this usually requires a subscription to a service such as Netflix or Amazon Prime. Some TV stations stream their newscasts but they are not allowed to stream most of the other program content. WiFi is not a replacement for Dish or DirecTV. If you are in an area with no cell service you will have no internet. If TV is important, stick with a satellite dish.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
2oldman
sch911
Basically it's a Verizon MiFi hotspot with a big antenna. So save some money and go with the Verizon MiFi Hotspot hardware which is what most of us use. When you're not close enough to a Cellular data signal there will be no service, this is just how it is.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
