Difficulty Finding Adaptor
mr__ed
I'm trying to attach a wired mouse to my iPad. I don't like Bluetooth mice because I've used them in the past and always had problems. My wired mouse has a USB-A plug and the iPad has a lightning port. I need a lightning (male) to USB=A (female) adaptor in order to accomplish this. All I can find are adaptors with USB (male). Walmart has dozens of adaptors, but they're all USB (male). I even checked online without success. Maybe they aren't manufactured for some reason. I would especially prefer lightning (male) to USB-A (female) with no wiring in-between, just a simple plug-in adaptor. In the meantime, I can continue using the track pad on the external Bluetooth keyboard, but a mouse would be preferable.
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
22 REPLIES 22
mr__ed
Seattle Steve wrote:
Sorry, Ed, but you should stop looking. Even if you could find or create your own adapter, it would not work. IOS is not designed to use a wired mouse and the IOS software does not support it. Frankly, iPads are not designed for mice; they are touchscreen devices.
Steve, I believe the 7th generation iPads now support mice, but Iโ€™ll check further. ๐Ÿ™‚
Yep, I just confirmed it online. The later generation iPads can now use a mouse!
Seattle_Steve
mr__ed
wanderingaimlessly wrote:
If I understand what you need, this could help.
double female usb connector
That,s not quite it, but thanks for searching. I need lightning connector male to USB-A female. The ones on Amazon, noted above, seem correct. Theyโ€™re meant for use with an iPhone, but may work with a wired mouse; not sure. Thanks
wanderingaimles
mr__ed
agesilaus wrote:
Try this Amazon
Amazon, tho vile, has jast about everything. I went to electronics and typed in USB female to Lightning male
Thank you, Agesilaus. Looks promising. I especially like that two of the adaptors have no wiring, just plug directly to devices. I don't know any reason why it couldn't work with a mouse, but maybe worth a gamble. ๐Ÿ˜‰
mr__ed
2oldman wrote:
This doesn't work? I do see it says 'camera.' Also, there's no such thing as a wired mouse with a lightning plug?
Thanks for the research, 2oldman. What concerns me, as you pointed out, is that it's meant to attach a camera to an iPad. So, I can't be sure it will work with a mouse (maybe different internal wiring?)
agesilaus
Try this Amazon
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
2oldman
