DirecTV transponder problem
Dayle1
My DirecTV setup worked fine 10 days ago. But moved to a new campsite and on Sunday I set the system up again. I'm using an 18" round manual dish and signal meter to locate the 101 sat. I got plenty of signal strength on the meter, but nothing on the DirecTV setup menu. But when I scrolled thru all the transponders, 3 were actually working with signal strength between 77% and 85%. They were numbers, 28, 30 and 32. All the other transponders were zero.
Rebooting the system did nothing. DirecTV tech support was worthless. So, on a chance I ordered a new LNB thru Amazon. I just swapped out the LNB without disturbing the dish. Didn't bother to recheck the signal meter. But no change, the same 3 transponders have 80% to 84% strength and all others are still zero.
Seems strange that this is a receiver problem, but what else is there? Anyone have ny ideas or suggestions. DirecTV today says they don't make service calls for mobile setups, to call Camping World for help.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
13 REPLIES 13
Bill_Satellite
Dayle1 wrote:
Dayle1 wrote:
So is everyone saying it is possible to be on the wrong sat. and still get 3 of 32 transponders to show 80+% strength???
Learned something new, on another forum one poster stated I was hitting 110W. He was correct, problem solved.
Good job! Well done. It's nice when posters come back saying they found the answer to their problem.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Bill_Satellite
edatlanta wrote:
I don't have to worry about finding the wrong sat since only use the Signal Strength meter built in to my Genie (or earlier DTV receivers prior to the Genie). I have a wireless baby monitor that I aim the camera at the signal strength screen on my TV, take the remote out to the dish and aim it. The directv system won't connect to the wrong sat so I never have the wrong sat issue. The baby monitor works great and is much cheaper than the high priced meters. I did have to buy a new battery for the remote a few years back that I think was in the $5.00 range.
Actually, the exact same scenario can happen with a Genie that the OP is describing. The Genie does tend to be better, but there are a number of satellites that will cause a few transponders to light up on any DirecTV receiver.
Dayle1
Larry Day
Rig Photos
jyrostng
Just a heads up for the future of SD. https://blog.solidsignal.com/news/end-coming-directv-announces-end-sd-service/
2000 F53 Southwind 32v
Triker33
Maybe it's time to get a Trav'ler?
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
edatlanta
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Dayle1
Larry Day
Rig Photos
Bill_Satellite
As others have stated, this will happen when pointed at the wrong satellite so you just need to get away from that sat, recheck your antenna settings and compass and give it another shot. When you are pointed correctly you will get a picture on the TV (check a non-network channel like Food on 231 or the DTV channel 100 which runs even without programming turned on).
Ivylog
X4 on wrong satellite. You should have asked on here sooner although now you have a spare LNB.
Upgraded with a 08 HR Navigator 45โ€™...
Ivylog
Double post.
jerseyjim
Quite a few years ago, I also had that problem. On the "setup" page, it even said "incorrect satellite". A simple re-aim solved the problem.
2oldman
bdpreece wrote:
Odds are you are not on the correct satellite.
x2.
With that setup you shouldn't need a meter, just use the beeps in the receiver. That way there's no mistaking for the wrong bird. You shouldn't ever need to look at the transponder strength either, just the horizontal bar on the Signal meters screen.
bdpreece
Odds are you are not on the correct satellite. Not sure what the sat near the 101 is but I have this problem periodically as it actually has a stronger signal than when I connect to the 101 and they are pretty close together.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
