โAug-30-2017 12:57 PM
โSep-01-2017 03:30 PM
โSep-01-2017 05:24 AM
โSep-01-2017 03:45 AM
โAug-31-2017 05:50 PM
โAug-31-2017 04:46 PM
โAug-31-2017 03:32 PM
โAug-31-2017 06:14 AM
Bill.Satellite wrote:
As a point of clarification, the thing you have been calling a dish is not a dish. The things you eat food from are dishes. The things that receive broadcast signals are antennas. The OTA "antenna" on your roof and the satellite "antenna" in a dome, on the ground or attached to a Trav'ler are used to receive signal broadcasts.
So......to answer your question, you need an antenna and an LNB. However, if you are using an HD receiver but connecting itmto an older SD TV you just need a simple single LNB that will let you point to and receive the signal broadcast from the 101 satellite. These cost about $15 (or less) and can be found locally quite often. Where you might have a problem is connecting your HD receiver to an older TV. Does the H20 have a coax output option? If not, your old TV will not have an HDMI input but it might have a 3 wire Red/White/Yellow RCA connection option.
โAug-31-2017 03:59 AM
โAug-31-2017 03:13 AM
โAug-30-2017 02:52 PM
nowgrn4 wrote:
Antenna? I'm sure you mean dish. Will this LNB work with my existing 20" round dish?
2oldman wrote:nowgrn4 wrote:Did you get HD with it before?
โAug-30-2017 02:08 PM
โAug-30-2017 01:38 PM
You need that same size antenna but now you just need the SL3 LNB like this.
SL3 LNB
You could also update to a SWM3 LNB but it really won't have any advantage with that particular receiver.
โAug-30-2017 01:21 PM
