Hopper 3 Installation
TechWriter
I had the new 16-tuner Hopper 3 installed last Saturday. Very impressive. I'll have more details lated, especially for RVers.
In the meantime, here's some details from my Hopper 3 install . . . keep in mind that it's pretty nerdy.
2004 - 2010 Part Timer (35โ€™ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41โ€™ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31โ€™ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
10 REPLIES 10
TechWriter
Bill.Satellite wrote:
Wonder if there's a way to change out the Winegard Trav'ler LNB and have the antenna still work......
For the Hopper 3, I'll let you know in a week when I test my H3 on a modified Travler.
However, I did test the new Dish Hybrid Pro Western Arc LNBF on my Travler connected to a Hopper with Sling (or "Hopper 2") -- it worked just fine. Details here.
Did you put the antenna up and down to see if it would lock on or was this down with the antenna up and locked on?
The Hopper 3 must be disconnected from the Travler when the Travler is in operation. Once the Travler has acquired the sats, the Hopper 3 can be reconnected. Using an AB switch makes it easy to connect/reconnect.
If the Hopper 3 is left connected while the Travler looks for sats, there's a good chance you'll get the Blue Screen of Death -- "No LNB Voltage".
DISH TV for RVs
Bill_Satellite
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
TechWriter
dave007 wrote:
TechWriter: I'm supposed to have the Hopper 3 installed Friday at my home with 5 joey 2.0's. If I have a Travler dish on my RV, can I use just the joey, or do I have to use the Hopper 3? Thanks
Nope. Joeys can't operate alone.
DISH TV for RVs
dave007
TechWriter
DISH TV for RVs
Bill_Satellite
TechWriter
hawkpat wrote:
Did you have to pay to upgrade to the Hopper 3?
Upgrade cost varies: $0 to $150. I paid $0.
hawkpat wrote:
Did the reduction in Hoppers lower your monthly bill?
By $10. I went from three Hoppers to one Hopper 3 + 2 Joey 2.0s,
az99 wrote:
Do they require the tech to come out to change over?
Yep -- and a good thing, too. Would not want to self-install a Hopper 3 just yet.
DISH TV for RVs
az99
Do they require the tech to come out to change over? What was the total cost?
gatorcq
16 tuners? I cannot even watch 3 tuner Hopper
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
hawkpat
Did you have to pay to upgrade to the Hopper 3? Did the reduction in Hoppers lower your monthly bill?
