How far north will the winegard Carryout work with directv?
dreamer
How far north will the winegard Carryout work with directv? Just curious, we are going to Alaska and will have it with us. Thanks.
dreamer.
'07 HR Scepter - 400HP
'02 Tracker
'02 Honda Reflex
'16 Chevy Silverado - M&G Brake System
'17 RZR 900 Trail
'17 RZR 1000 High Lifter
How does it feel
To be on your own
With no direction home
Like a complete unknown
Like a rolling stone? - Bob Dylan
9 REPLIES 9
PA14Jim
Thank you
Jim
Jim
02 Travelaire Gensis
03 GMC Duramax
Bill_Satellite
Yep.
Can't we all just get along?
STBRetired
PA14Jim wrote:
My direct (24) was hooked up to the house antenna 9 days ago, now we are in Ashland wi. What do I select as my antenna type using my winegard carryout 12v antenna?
18"round, I believe.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Bill_Satellite
There certainly is reception of DirecTV in Canada with a Carryout style antenna. Not very far, but it certainly is available. Our dome worked in Lake Louise, Calgary, Banff and the entire Highway 2 between BC and Calgary. It also worked in Eastern Canada from Toronto to Nova Scotia.
While in Lake Louise my dome had a signal strength of 60 while the open faced antenna next door still had an 80+ signal. So while I could not have gone much farther North, the open face antenna certainly could.
PA14Jim
Jim
03 GMC Duramax
dreamer
Thanks for all of the replies. Reception about what I was thinking.
dreamer.
'02 Tracker
'02 Honda Reflex
'17 RZR 900 Trail
How does it feel
To be on your own
pigman1
Although dish size does have some impact on signal strength, the real limiter is how far down toward the horizon the dish will tune. In many domes and the Winegard Trav'ler, that is 15-20 degrees above the horizon. With the satellites located above the equator, this means that about the furthest north you can tune their signal is the Juneau latitude. In fact, I have gotten DirecTV from Douglas, four miles south of Juneau across the channel. We were on a Trav'ler without modifications. By playing with the antenna geometry (I put a nickel in the antenna LNB arm pinch point) and got DirecTV in Valdez. Another major problem is that when tuning to within 15 degrees of horizontal in Alaska this puts a lot of mountains in the way.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
Bill_Satellite
No Alaska reception. A standard size DTV antenna can get some SD reception in AK but the satellite is so low the dish will actually be pointed at the ground when aimed correctly.
A dome will work into Southern Canada and possibly a bit farther N. but we were in Lake Louis and had reception but a very weak signal. The RV beside us with an open face antenna still had an 80+ signal.
gatorcq
Direct TV, you can forget alaska, as dish size is over 3 Ft.
Possible just into Canada.
We were there in 2015
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
