If You Had $300 To Spend On A Laptop...
MEXICOWANDERER
Where would you go and what would you buy? Alicia, the owner of the market where I help out and use the modem has six hundred dollars and change to purchase 2 laptops for 2 grandsons. They surf the net and play video games. I would believe 15.6" size offers the best value battery RAM and storage for the buck? Above all else I must avoid possible land mines where I buy something then find out it's bad after they get here. Alicia has the Spanish Windows 7 program plus profession office in Spanish.
Links hints warnings tips and suggestions much appreciated!
25 REPLIES 25
Tvov
+1 to what bighatnohorse posted... I buy from NewEgg all the time, they are great. If you can't buy from NewEgg directly, you can use their site to look over a wide range of laptops and read reviews.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
road-runner
RLS7201 wrote:
Look closely, at the DC connector, there is a outer shell and inner shell that carries the power to the LT. HP/Dell LTs look for a coded signal on the small pin in the center. When the coded signal is not present, the LT will function but the battery will not charge. Now you know.
I confirm all of this for Dell laptops. That signal wire has a habit of breaking from flexing at the DC plug, resulting in the message that the laptop will run, but the battery will not charge.
2009 Fleetwood Icon
Heisenberg
The Asus Vivo at Best Buy is an excellent deal for this price range.
2013 Winnebago Sightseer
2017 Colorado
Bill_Satellite
Asus?
Can't we all just get along?
FordDiesel250
I would go to Wally World and purchase two Asmus I believe is the brand and walk away with a couple of good putters.
RLS7201
ktmrfs wrote:
RLS7201 wrote:
One caveat about HP & Dell LTs is there 3 wire power supply. You can NOT use an aftermarket power supply with them. I like running a after market DC-DC power supply in the MH. With a HP or Dell, you'll need to fire up an inverter when off grid.
Richard
I've had 3 HP laptops and 2 Dells that all had the ability to run off a 12V power supply that was available. same plug as the HP, just a 12V input to the charger instead of 120V. In fact two of the HP's had chargers that accepted either 12V or 120V inputs.
I sit corrected. It was only Dells that had the unique power supply
See LINK.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
ktmrfs
RLS7201 wrote:
RoyB wrote:
Richard
My DC requirement for my DELL INSPIRON 17R5737 is 19.5VDC @ 3.3A and uses a standard round DC connector with center pin on the DC output cable that plugs into the laptop.
The DELL 6TM1C external Transformer does have a three wire connection to 120VAC which I assume is two 120VAC wires and a ground connection... The DC output from this transformer uses a long cable with a standard size round DC connector that plugs into the laptop.
To run from an external DC Power Supply would only require the round standard DC connector plug and a +19.5VDC @ 3.34DC Amps capacity????
I don't see any problem running this laptop using an external DC power supply that would have 19.5VDC @ 3.34A capacity available.
I don't think I understand your comment about the three wire connection...
Roy Ken
Richard
my current two HP's and one Lenova have the connector your talking about and I have 12V aftermarket power supplies for all of them that work great. Charges battery, runs the laptop. Just make sure the unit is spec'd for the laptop you have. I've bought all the 12V chargers off amazon.
2011 Keystone Outback 295RE
ktmrfs
Richard
MrWizard
Moderator
Moderator
Yeah..x2 on the game's
With that modem connection at the store, the kids are not going to be playing
Call of duty, Warcraft etc..
Laptops, notebooks etc... Are going to be used on the table etc..
And not carried around and dropped like what might happen with a tablet
Also play games with a mouse, not finger taps on the screen
How old are these grandsons?
That is also a factor in choice
I can explain it to you.
1997 F53 Bounder 36s
bighatnohorse
I bought a $200. Dell laptop: THIS ONE from the NewEgg Outlet Store
The outlet deals come and go. The Dell I bought was a good competent machine for a 12-year-old.
(Actually, I could have used it myself and was a little bit envious.)
The price was actually $179. or so (I forgot exactly)
It was "refurbished". On close inspection the only sign of use was some very light small scratches near the USB outlet on it.
NewEgg is a good store. I've bought from them for years. Hope that they ship to Mehheco.
As for "gaming" - I'd bet that the kids use "free" games - just no money for the really good games that demand high-end computers.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
โ€œThe best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
theoldwizard1
I "inherited" a low end HP laptop. It only had 4GB of memory, so I upgraded it to 8 GB (which is the max). I also upgraded Win 8 to Win 10. The thing is a DOG and I don't do much more than "surf the web" and email.
If you are on a tight budget, find a 2 or 3 year old used machine and install Linux Mint.
RoyB
RLS7201 Richard... Thanks for the info... I will check that out... First glance just looks like one of the standard round DC Connectors...
I'm all setup with Power Inverters for charging things when off grid but nice to know how things really works....
Thanks again for the info...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
STBRetired
look at refurbs, like the ones in the PM I sent you. Best bang for the buck as long as you aren't looking for cutting edge tech.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
RLS7201
RoyB wrote:
Richard
Roy Ken
Richard
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
