SSD Drive Read Errors
TenOC
My laptop has a Kimtigo SSD 512GB hard drive. It is divided into 2 partitions. Windows 10 operating system is on the C: partition. All data is stored on the other F: partition. I have good backups of both partitions that are about 6 weeks old. When I attempted to back up (differentially) the F partition today, I get 30 read errors. ScanDisk shows no errors. If this was a spinning hard drive, I would do a surface check.
I will be replacing the drive as soon as I can get one on order. I will probably upgrade to 1 TB SSD drive
Is there a good program to check a SSD drive?
Should I clone the old drive to the new drive or is it better to do a full reinstallation of Windows 10? My laptop will not support Windows 11.
All thoughts and comments are welcome.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
1 REPLY 1
joebedford
Nomad II
Nomad II
Crystaldiskinfo gives all the "smart" parameters so you can see how sick your drive thinks it is.
Personally I think that if you don't have a lot programs that won't get transferred over, it's better to do a clean installation, otherwise clone.
If you can, it can be useful to keep the failing drive on your PC. If it's a desktop, use another SATA port. If it's a laptop like mine, use an external box with USB connection. The one I use is:
https://www.amazon.ca/Sabrent-Tool-free-Enclosure-Optimized-EC-UASP/dp/B00OJ3UJ2S/ref=sr_1_1_sspa?cr...
