King dome satellite fuse location: Fleetwood Bounder Diesel
lbond01
I do not use my factory installed King Dome Sat system on my 2004 Bounder Diesel model 39Z. while in sitting in stowage, the sat dome on the roof started making a clicking noise and the wired display is flashing led numbers. I want to down power the system. I can't seem to find the fuse for the system. Right now the coach battery disconnect is open, so I know it is coach powered. Before I start pulling fuses, I thought i would ask here. I'm sure some out there knows. I'm guessing a spare or aux spot.
Leo
2004 Bounder Diesel 39Z
Freightliner with 300 Cummins
Pressure Pro Tire Pressure Monitoring
110 Watt Solar
0 REPLIES 0
