Linux Ubuntu problem
BarneyS
I run Ubuntu on one of my laptops. Recently, an "update" came through and when it was done, my laptop WiFi was gone. I have no signal indicator at the top and I cannot connect to my router any longer to get online. Now there is no way to fix the problem via an update or other download. Anybody have suggestions.
I have already tried to use Windows to download the latest version but it will not install, probably due to the older version already being installed. Also, I cannot find any way to uninstall Ubuntu. Anybody know how? Keep in mind that I am not an expert in either computers or especially Linux.
Thank you.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
12 REPLIES 12
1492
Moderator
Moderator
Didn't realize you were using a dual-boot environment? Which can sometimes cause problems with OS upgrades.
As I mentioned, I'm not familiar with Ubuntu. However, I would check to make sure your specific WiFi adapter is enabled using Ifconfig? I believe Ubuntu should do this automatically? But still wondering if the upgrade disabled the specific network adapter?
CentOS, which I'm more familiar and just basically a free version of Red Hat Linux Enterprise, does not enable network adapters by default. No wifi or ethernet. You have to manually enable the adapter(s), or else modify the specific script option to "onboot=on" to avoid having to do so upon startup each time.
road-runner
Not what you asked about, just want to throw this in. I tried ubuntu for a while and didn't like it a whole lot. Switched to mint cinnamon 17.3 and like it much better just because the GUI is pretty close to the windows gui. If you're not familiar with it, you will also want to get grub customizer (for either mint or ubuntu), which IMO should be a standard part of the system. You can burn a bootable DVD of mint and boot without installing it to try it out.
2009 Fleetwood Icon
BarneyS
Thanks Chris and all the others who made suggestions. I have given up and used my system restore disks to put the computer back to factory original. That went fine and now am installing Windows 7. t Then will try my backup that I made some time ago. It should have most of my programs and settings on it. If not, I have a lot of work to do yet installing all the programs. I am not going to install all of them though. There were a lot on there that I never used.
Just waiting now for Windows 7 to finish installing and then I can get to work again. Has been a long day on the computer! I am going to keep this little netbook that I am using now on Ubuntu, but not going to put it on the laptop again.
Thanks again for all the help. 🙂
Barney
Not towing now.
Chris_Bryant
For kicks try:
sudo service network-manager start
and see what happens:)
-- Chris Bryant
BarneyS
Got home and tried all of the suggestions given. Not much luck!:(
I am running Ubuntu 14.04 LTS. It is on a Toshiba L305 64 bit, running Windows 7 Home Edition with Ubuntu as an optional boot.
Using Windows right now to get online.
Chris:
I tried both of your suggestions and could not decipher the results. Here is what came up on the screen. Perhaps you can explain them?
Results of Chris Bryant suggestions:
HERE IS WHAT I GOT WHEN I TYPED nm-connection-editor:
"** (nm-connection-editor:2607): WARNING **: Could not initialize NMClient /org/freedesktop/NetworkManager: The name org.freedesktop.NetworkManager was not provided by any .service files
(nm-connection-editor:2607): GLib-GIO-CRITICAL **: g_settings_new_with_path: assertion 'path_is_valid (path)' failed
(nm-connection-editor:2607): GLib-GIO-CRITICAL **: g_settings_get_value: assertion 'G_IS_SETTINGS (settings)' failed
(nm-connection-editor:2607): GLib-CRITICAL **: g_variant_get_type: assertion 'value != NULL' failed
(nm-connection-editor:2607): GLib-CRITICAL **: g_variant_type_is_subtype_of: assertion 'g_variant_type_check (type)' failed
(nm-connection-editor:2607): GLib-CRITICAL **: g_variant_get_boolean: assertion 'g_variant_is_of_type (value, G_VARIANT_TYPE_BOOLEAN)' failed
(nm-connection-editor:2607): GLib-CRITICAL **: g_variant_unref: assertion 'value != NULL' failed
(nm-connection-editor:2607): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nm-connection-editor:2607): WARNING **: Invalid setting Wi-Fi: ssid
barney@barney-Satellite-L305:~$
___________________________________________________________________________________
HERE IS WHAT I GOT WHEN I TYPED nm-applet:
"barney@barney-Satellite-L305:~$ nm-applet
** (nm-applet:2768): WARNING **: Could not initialize NMClient /org/freedesktop/NetworkManager: The name org.freedesktop.NetworkManager was not provided by any .service files
(nm-applet:2768): nm-applet-WARNING **: Error connecting to ModemManager: Error calling StartServiceByName for org.freedesktop.ModemManager1: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ExecFailed: Cannot launch daemon, file not found or permissions invalid
(nm-applet:2768): nm-applet-WARNING **: Could not find ShellVersion property on org.gnome.Shell after 5 tries
(nm-applet:2768): nm-applet-WARNING **: Failed to register as an agent: (2) The name org.freedesktop.NetworkManager was not provided by any .service files"
Thank you very much for reading that long quote and for the help.
Barney
Not towing now.
BarneyS
Thank you all for the suggestions. I am on the road right now but will try them out on my laptop when I get home in a few days. I'll update the thread if any work or not.
Barney
Not towing now.
Chris_Bryant
You could also try just running network manager- you should be able to search and find it. If not, try opening a terminal and running either:
nm-applet
or
should open the network manager.
-- Chris Bryant
1492
Moderator
Moderator
I'm not that familiar with Ubuntu. I believe some members are actively using it?
Just stood up CentOS on a surplus Xeon workstation as local lamp stack dev box last week, though it's based on Red Hat Linux Enterprise, so don't know how similar it is?
Worse case if unable to roll back, you could reformat the drive for clean re-install of Ubuntu? Use a free self booting utility such as GParted. Make sure to save any files first.
Chris_Bryant
Which version are you using? I would first try choosing advanced options on the boot screen, then the previous kernel.
-- Chris Bryant
Gene_Ginny
There is also info here: http://askubuntu.com/questions/55868/installing-broadcom-wireless-drivers but I think the link from bwanshoom is probably better.
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
bwanshoom
See if the information in this thread helps
2010 Cougar 322 QBS
2008 Chevy Silverado 2500HD LMM CC/SB 4x4 LTZ
Pullrite SuperGlide 18K
JayGee
Can you connect via wire direct to the router?
Jaygee
2005 Bounder 35E on F53 chassis
