Ok...whats left to check on my dish.......
bobsue2
Couple months ago while camping in Ga...wind blew over my dish a couple of times...the last time it happened, I couldn't get a signal...removed the LNB and tapped it on a rock...reassembled and poof...we had a signal the rest of the time there.....
Returned to Fl and parked it a the usual spot...set the dish back up and couldn't get a signal no matter what I tried...ordered a new LNB and tried it again this weekend...still couldn't get a signal even when running the cable directly from the dish to the receiver using different cables.
I have the receiver set up utilizing the "Slimline-3" and aiming for the 101...what else is there to check for....please note that we've parked here several times over the past few years so I know exactly where to point to get a signal....thanks for any replys
2013 Key Largo
12 MegaCab 3500 DRW 4x4 18k Superslide 19.5 Michelin LDX-2
16 REPLIES 16
schneid
LNB finally succumbed to its injuries?
filthy_beast
Could the dish itself be be bent, even slightly?
Goody Two Shoes and the Filthy Beast
2008 Silverado 2500HD
2012 Wildcat 282RKX
You cannot make things idiot proof, you can only make them idiot resistant.
