โJun-10-2013 05:25 AM
โJun-10-2013 04:10 PM
โJun-10-2013 01:27 PM
โJun-10-2013 10:09 AM
gscudder wrote:
The sticker above the coax cable jack on the side of my BRAND NEW 2013 Dutchman Voltage says "Cable/Satellite".
Gregg
โJun-10-2013 10:05 AM
tanman32225 wrote:Bill.Winegard wrote:
There should not be a cable connection on your coach that is labeled Cable/Satellite since these would either need to be 2 separate connections or there would have to be an actual A/B switch (not a video switcher) inside the coach that would allow that one single cable to go directly to your satellite receiver when connected to satellite or to the cable splitter for that programming to go directly to your TV's.
The coax cabling in the RV is not the issue (unless it's damaged) as the older RG-59 (never heard of RG-8 being used in an RV)runs are short enough as not to be at issue if your coach happens to have them.
What kind of coach is this and is it new or used.
Not trying to undermine you but some of your information is either incorrect or old school. You DO NOT need a separate sat cable. Both sat or cable can feed on the same line if and only if there is not a splitter between the source and the sat box. You cannot split that input cable and you DO NOT need an A/B switch or separate line for cable and the Sat.. If the line coming in has integrity with good connections the either/or satellite or cable can use the same line if the pre-mentioned parameters are met however not at the same time obviously.
I have one line in. I use either sat or cable.. either/or to feed my system.. NO A/B switch needed. I would be happy to send u Dutchmen schematic if you would like to peruse it for how its done.
โJun-10-2013 09:34 AM
โJun-10-2013 07:23 AM
โJun-10-2013 06:49 AM
โJun-10-2013 06:27 AM
โJun-10-2013 06:15 AM
โJun-10-2013 06:11 AM
โJun-10-2013 05:51 AM
โJun-10-2013 05:31 AM
