โAug-08-2014 10:58 AM
โSep-01-2014 04:54 AM
โAug-31-2014 07:03 PM
johndeerefarmer wrote:Bill.Satellite wrote:
The 211Z is the issue. If you still have your Anser, hook the 211K to that and point to 72.7. You will be able to get through the receiver actiavation and once you are watching TV you can hook things up to the G2, do the new check switch EXACTLY following the instructions and you should be good to go.
I already have it working after I had hooked it to my home dish. Too bad that neither the G2 or the DISH manual gave me a clue as to what to do
โAug-31-2014 06:44 PM
lryrob9301 wrote:johndeerefarmer wrote:
I received the G2, then called DISH and had my DP301 activated. It would never work (even when connected to my home dish). After multiple phone calls and hours wasted they told me that the DP301 was too old and would not work with current technology. So I bought a 211z. I had it activated this morning. I spent most of the day getting the 211z and G2 working. I would disconnect the SAT in cable, run the "test switch" to clear any previous setting, then connect the SAT cable, run the "test switch" again and I would never get a signal or SW64 would never appear. After doing this multiple times I finally connected my 211z to my home dish to make sure that it was in fact working and it was. I then connected my DVR to the G2 and did the test switch twice as instructed. The DVR worked with the G2. I then reconnected my 221z to the G2, ran the test switch and now it's working. What a deal! If I hadn't of had my DVR and home satellite to aid me in the troubleshooting I would still be sitting here working on it.
My only hope is that the 211z will save the settings and the next time I connect it to the G2 it will work without problems.
I am beginning to think that the semi-automatic Anser was a whole lot faster than the "automatic" G2.
Has anybody else had issues getting the G2 and 211 to work together without having to go through all of the******that I did? Got any tips in case I have this trouble again.
Thanks
The reason you had a problem is the 211Z does not have the latest programming installed. When you connected it to your home dish it automatically updated it's programming. It will now continue to work with either the home fixed dish antenna or the automatic G2. Neither DISH network techs nor some Winegard techs are aware of this. It is recommended to take a new 211Z to a local DISH retailer for the upgrade before using.
โAug-31-2014 06:43 PM
โAug-31-2014 06:26 PM
Thanks
โAug-31-2014 06:23 PM
โAug-31-2014 05:08 PM
โAug-08-2014 09:51 PM
โAug-08-2014 04:49 PM
โAug-08-2014 04:25 PM
