RG6 Coax
NancyG
We purchased the Tailgater and would like to make use of our outside connection for Satellite, rather than running coax through a slide and directly into receiver. How can we determine if the connection for satellite on outside of fiver is RG6? It runs from outside the trailer into the entertainment center to an outlet marked Satellite. We have tried this connection but cannot get it to activate. We bought Radio Shack RG6 for use between Satellite In connection and the Receiver.
Update: noted that Radio Shack coax is marked RG6-U and coax in Satellite connection is RG6. Could this be the problem?
GeneandNancy
MtnDreamers
2007 35.5' K-Z Sportsmen LX Fifth Wheel
2008 Dodge Ram 3500 Dually Laramie Quad Cab 4WD
21 REPLIES 21
NancyG
Thanks...the connection from Tailgater directly to Receiver (thru slide opening)works fine. We just wanted to use exterior outlet leading to Satellite In position if possible. We will be tackling this challenge tomorrow. Thanks for clarification of RG6 and RG6-U labeling. appreciate all replies.
GeneandNancy
MtnDreamers
jhilley
RG6 and RG6U are the same.
2003 Winnebago Adventurer 38G F53 Chassis Solar Power
1999 Winnebago Brave 35C F53 Chassis Solar power
Handicap Equipped with Lift & Hospital Bed
1999 Jeep Cherokee Sport
1991 Jeep Wrangler Renegade
BB_TX
Connect directly to the Tailgater first just to make sure it is working properly. (I assume you have a 211 receiver??)
If so, start working with the RV. A short run of RG59 in the RV will work fine. At least it did on mine. You will likely have to start tracing the internal wiring if it does not work correctly in the RV. The coax from the external connection should go direct to the internal connection for the receiver.
powderman426
sljkansas wrote:
If the coax you are using has a splitter in the line for the TV/cable connection, the satellite signal will not pass through it.
Yes. And a lot of then do have a splitter. My friend solved the problem with one of these and a piece of coax directtly to the tv inside.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
sljkansas
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter Married.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
CA_Traveler
Set it up to work with the TG directly connected to the receiver. Then move the TG coax to the AV output coax and connect with a barrel connector (female to female connector from RS) and keep working back until you isolate the problem.
You can also use a test light or ohmmeter and a long test wire to trace the coax in the rig.
2014 Grand Cherokee Overland
Bob
Bill_Satellite
Whether the coax in the fiver is RG6 or RG59 you should have success and I would not be concerned about what's inside. Now, if you want to try to use a connection labeled Cable to provide a connection to a satellite antenna, this will not work or will not work without some cabling modifications.
Can't we all just get along?
