โJan-04-2015 08:03 PM
โJan-05-2015 02:23 PM
deppeler wrote:
Hi,
I have a 2015 Kodiak TT with a 12v DC 8 amp outlet (winegard amp plug).
I have a 120v 29" LED TV that has an output of 42 watts.
My question, can I plug an PSW inverter into the 12v DC outlet to power the TV?
If so, what would be the maximum size inverter I could use in the 12v outlet?
Thanks
Paul
โJan-05-2015 09:06 AM
โJan-05-2015 07:11 AM
deppeler wrote:Maybe. Most of us have better luck with 4 batteries.
a 1500w PSW inverter (and 2x 6v deep cycle batteries), could I leave the microwave breaker turned on then?
deppeler wrote:Yes. You don't have to flip the breaker, it's just a reminder. If you happen to try to run it the inverter will just shut down. Nothing will explode.
Is the microwave off because of the power draw if accidentally turned on?
โJan-05-2015 07:09 AM
deppeler wrote:Small inverter to a single branch circuit is fairly simple. Especially if you have space near the fuse/breaker panel.smkettner wrote:
8 amps 12 volts = 96 watts. Stay a bit under for best results.
Or wire in an inverter to the regular outlets.
Thanks for the info, is it complicated to wire it into the regular outlets?
โJan-05-2015 06:55 AM
โJan-05-2015 06:08 AM
2112 wrote:deppeler wrote:I also have a 400W MSW that connects to the battery with alligator clamps like on jumper cables.
You can turn OFF your converter and microwave at the breaker panel, set the fridge to propane and plug your shore power cable into the inverter using a 30A-20A adapter. All 120VAC outlets will have power at this point. Make sure the electric water heater and Air Conditioner are powered OFF
I went one step farther but I'll spare you this.
โJan-05-2015 05:55 AM
โJan-05-2015 05:39 AM
โJan-05-2015 05:25 AM
โJan-05-2015 05:14 AM
โJan-05-2015 04:15 AM
โJan-05-2015 04:05 AM
โJan-04-2015 08:38 PM
โJan-04-2015 08:26 PM
