Samsung S7 and PdaNet / FireFox
sherlock62
Just letting anyone here that might be interested know that PdaNet / FireFox works aok with the Verizon / Samsung Galaxy S7 and S7 Edge.
12 REPLIES 12
MrWizard
Moderator
Moderator
I have a grandfathered unlimited data plan
If I try to use hotspot without Firefox
I get redirected to Verizon, for activation charges
I can explain it to you.
1997 F53 Bounder 36s
sherlock62
djgodden wrote:
Verizon no longer charges for using your phone's hotspot capability. We use it all the time, no charges, good connections. I used PDAnet before, was generally reliable.
you are not up to speed on this topic. Grandfathered, Unlimited, Verizon plan people still have a use for PdaNet / FireFox. Those reading your post should discount it.
djgodden
2012 Ram 2500 4x4 Lariat Longhorn 6.7 CTD HO, Edge Evo CTS, Extreme Tow/Haul brakes, aFePower Diff cover, LL 5000 bags, 285/70R17, Reese Q20 w/slider. 2005 Montana 2955RL w/400w solar, Renogy MPPT, 4 x 6v @ 12VDC (450AH), 3000w Inverter, King VQ4100.
Belgique
Thanks Mr. Wizard. Understand.
Hickory, NC
2007 Fleetwood Discovery 40X
MrWizard
Moderator
Moderator
Verizon used to charge an arm and leg
For the privilege of wifi hotspot
Instead of the current ,? Low $10 add-on fee
Also Verizon does not allow hot spot or tether if you have a grandfathered unlimited plan
They allow new plan customers to hotspot because they want them/you to use up your 3 gig plan allotment and pay for overage
Belgique
Not being a wise guy...serious question: why do I need PDA Net since the (Verizon) S#'s have a hot spot capability. Is there some advantage I'm missing? Thanks.
Hickory, NC
MrWizard
Moderator
Moderator
thank you
sherlock62
MrWizard wrote:
What carriers
I have only tested with the Verizon network as I mentioned in the original post.
MrWizard
Moderator
Moderator
What carriers
Wrace
Thanks sherlock, that is encouraging.
sherlock62
MrWizard wrote:
well that is welcome news
how about a thorough test..please
Not sure what you mean by a "through test" but can tell you that PdaNet / FireFox works without issue with the S7 just as it did with the S5 and S6. In regard to testing, I have been a beta tester of the app and know the in's and outs lets call it. Anyway S7 is aok with PdaNet / FireFox.
MrWizard
Moderator
Moderator
