Satellite 119 with DISH seems to cut in and out on motorhome
jeeperdude10
We have a winegard satellite which was installed at the factory, came with our coach. We have a Wally with DISH and all worked well for over 3 years now, my problem just popped up and it is with the satellite 119, seems ALL channels on that satellite are fine for about 5 minutes then switches to SD and or Total signal loss. Is there a chance this may just well be the WALLY is bad? Anyone else have an issue with? We have called DISH, and all we get is the routine...unplug, reset, let it do it's thing, etc.
2016 Bounder 35K
2014 Freedom Edition JEEP Unlimited
Traveling thru this great country
25 REPLIES 25
DFord
Use this map:
Western Arc:
Western Arc - Satellites: 110, 119, 129
Use the Western Arc if you are in this region. Local channels will be available while traveling within your local service area.
Legacy Western Arc
Western/Legacy Eastern Arc Overlap - Satellites: 110, 119, 129
Use the Western Arc in this region to receive most HD channels.
However, most local channels will not be available. Use the Legacy Eastern Arc (110, 119, 61.5) in this region if you are traveling within your local service area and wish to receive local channels. However, some HD channels may not be available in this arc.
Legacy Eastern Arc:
Legacy Eastern Arc - Satellites: 110, 119, 61.5
Use the Legacy Eastern Arc if you are in this region. Local channels will be available while traveling within your local service area.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
Larry-D
Got an email last week that the Wally receivers needed a software update. Did it over the weekend, so far no issues.
steveh27
I've been losing all signals a couple days a week at my house for a week or so. This is not during a storm. I have the 211k box.
BB_TX
We have not used the sat in the RV for a while, but home has seen no problems. Only time ours ever shifts to SD is sometimes during storms. And even that has occurred less and less the last few months, even rarely losing signal altogether as it used to.
BillyBob_Jim
Bill.Satellite wrote:
DISH has a software issue with RV domes. They are promising to fix the problem but it' been going on for awhile now and there is not yet a resolution.
I think Dish recently changed something somewhere. I have set up a tripod mounted 1000.4 on Eastern Arc for the last 8 years, in the same park, in the same exact location, on Memorial day weekend. Just pull the 211K out of the house where its connected to a 1000.2 WA dish, and set it up at campground on the EA setup. This year no dice. Despite having strong signal on all 3 birds, could not get the locals I could get before (same locals as home) and lots of the HD channels would throw the partial or total signal loss errors and revert to the SD equivalents. I had to have Dish change the zip code, and flash the receiver, which did get me locals from the middle of the state, but still having some issues with some HD channels. I've moved and re-peaked the setup now 3 times. As far as the locals from the middle of the state, I am only 28 miles east of home and know for a fact I am still in the local spot beam for the western side. Dish something amiss I think.
I suspect they have moved some channels around, either between birds or transponders, and do not have the bugs worked out yet.
Bill_Satellite
Can't we all just get along?
2112
We have been having the same problem in the S&B for the past few weeks. Partial to full signal loss. Sometimes it says we are experiencing a weather event but there is not a cloud in the sky. Signal is 50+ when it's working properly. Irritating.
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
MarkTwain
Call Dish again and tell them how many times their tech support have tried to resolve your problem. Tell them you want them to send a Dish tech person out to your RV to diagnoise the isssue.
rk911
wow...you can see the sun?! what's that like? been so long here since we've seen it. the dog had a peek at it the other day and freaked out! oh, sorry. off topic. :B
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
DFord
I'm using Dish in my house and on the HM also. Here lately at home between 5 and 7 pm we've been experiencing the complete signal loss intermittently. The strange thing is, when we press the GUIDE button during one of these episodes, the picture comes back in the window and stays there. Eventually, the Guide times out and switches back to full screen where we get the signal loss message again. We're using a Vip211z receiver. I think the problems has to do with the sun overpowering the satellite signal but I'm not sure.
Don Ford
rk911
obstructions?
Rich
'46 Willys CJ2A
'10 Jeep Liberty KK
