Traveling to east coast with Dish Network
LScamper
I’m in the planning stage of a trip to Long Island for about a month in the spring. I have Dish Network with a 1000.2 western arc antenna and VIP211K receiver.
I’m wondering if there is a problem receiving the satellites, especially 129W, because of the low elevation of the satellites from the east coast.
Anyone have any experience with using western arc antenna on the east coast?
Also, I have tried to aim my 1000.2 western arc dish at the eastern arc satellites 72.7W and 61.5W from home in New Mexico. I was able to get them and received many channels on 72.7W but none on 61.5W. Is there any programming on 61.5W? If there is useful stuff there what do I need to receive it? Would this be a good option on the trip?
Lou
12 REPLIES 12
TechWriter
Dutch_12078 wrote:
Here's a list of what's carried on 61.5. The "Conus Beam" listings are pretty much nationwide, but they may not all be viewable using a Dish receiver due to encrypting.
If you're staying in Long Island, you would probably be getting NY locals.
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
Dutch_12078
LScamper wrote:
That is what I thought. Did not know if there was any other programming on 61.5 that was not spot beamed.
Adding camp site number to the address to avoid conflicts is a great idea, thanks.
Dutch
2001 GBM Landau 34' Class A
LScamper
Dutch wrote:
"The locals are spot beamed based on your location. You likely will not receive any 61.5 locals in NM. When you're in the east, you can call or chat with Dish support to change your service address (NOT your billing address) to your current location to receive the locals for that area. If you're in a campground or RV park, include your site number as an extension of the street address, to avoid conflicts with other Dish users using the same address."
Lou
Dutch_12078
LScamper wrote:
Thanks for the info.
From what I'm reading I should be able to use western arc satellites unless there are trees in the way at low elevations. If this is the case I can swing my antenna around and point to 72.7 to receive most of my programming.
An eastern arc LNB might make receiving the eastern arc satellites easier. I can lock on to 72.7 with my western arc antenna without much trouble here in New Mexico.
I can also lock on to 61.5 here at home but don't get any programming. I don't know if I should get anything or if I would get anything using an eastern arc LNB. I don't see why an eastern arc LNB would get me any programming on 61.5 if I don't get it with what I have now. If the locals are on 61.5 and I can't see them maybe I have to call dish and tell them I'm on the east coast.
Dutch
LScamper
Lou
TechWriter
paulcardoza wrote:
Isn't the Eastern Arc version 1000.4 ?
The 1000.2's standard configuration is Western Arc. The 1000.4 standard config is Eastern Arc.
However, both the 1000.2 and 1000.4 can be made into either Eastern or Western Arc dishes.
DISH TV for RVs
I_rv
61.5 is pretty much local networks and sd broadcast, 72.2 has everything else and unless you want the spanish channels you don't need 77,the newest dish for east arc is only 2 lnb simalar to the dish 500.if you have a dish 500 with dpp (dish pro plus)lnb just use one lnb connection,set the skew angle at 90 and aim at sat 72.7 this works perfect with 211 receiver.to aim dish go to aim dish screen, select dish 300 and sat 61.5 put in zip code the cordinates you get add 5 degrees elevation and aim about 5 degrees to the right (west) and you will hit 72.7 very easy,don't forget to run check switch you will get everything
paulcardoza
TechWriter wrote:
Bill.Satellite wrote:
Long Island specifically would not be a problem unless your view is blocked.
Check www.dishpointer.com . . . in Long Island, NY your 1000.2 will be at about 24 degrees elevation which is really low. With Eastern Arc you'll be at about 43 degrees.
Do yourself a favor, get a 1000.2 Eastern Arc Twin LNB (sats 61.5 and 72.7) for your 1000.2. Then you'll be able to shoot over bushes.
Paul & Sandra
Plymouth, MA
2014 Heartland Cyclone 4100 King
TechWriter
DISH TV for RVs
Bill_Satellite
Other than the extreme NE and SE (with the exception of trees) you will be able to receive the 129 (110 and 119 are rarely at issue) programming without issue.
There are a number of tools available to you which can help you determine the location of the satellites and assuming you have a clear view you should have no issues at all. Long Island specifically would not be a problem unless your view is blocked.
Can't we all just get along?
K_Charles
Unless you are in a big open field 129 is hard to get here in CT. I have an old carry out that I aim at 61.5 and get enough TV for me.
I have used a dish 500 in Maine and RI and found 129 but like I saiddon'tt try it unless your on a hill
nazpaz
Others will know more about this than I do but when we were in PA this summer the HD locals were on 61.5. I have a Wineguard Carryout and was able to use the dip switches to program it to use the eastern arc.
I will also mention that the reason I ended up going to the eastern arc was that I couldn't get 129 because it was so low on the horizon and the trees were so tall.
Hope this helps.
-G.R. "Scott" Cundiff
Our Here and There Blog
2005 Safari Cheetah 38PDQ
We've visited them all (but not always with the RV)
