โNov-10-2017 05:24 PM
โNov-15-2017 10:20 AM
โNov-15-2017 09:41 AM
GordonThree wrote:
On many APC, at least the more expensive SmartUPS line, there's an adjustment on the back near the power cord accessible with a small screw driver that makes the unit more or less sensitive to "bad power"
โNov-15-2017 09:12 AM
โNov-15-2017 09:01 AM
dryfly wrote:
Could one assume that all APC and CyberPower UPS's will in addition to providing battery backup, smooth the output A/C power? Reason I ask is that I'm in the process of installing a Generac whole house generator and while the specs look good, I still have some issue with the powering of some electronic gear. I'm just not sure if the Generac truly puts out pure sine wave voltage.
โNov-14-2017 10:10 PM
โNov-14-2017 05:19 PM
Gdetrailer wrote:
You should also understand that many UPS units will not and cannot work with a generator as a input source.
As far as running electronic equipment from a generator goes, should be perfectly fine for 99.9999999% of the equipment out there..
โNov-13-2017 02:24 PM
Dutch_12078 wrote:Gdetrailer wrote:
Pretty much ALL of the APC UPS versions are MSW, not sure about "Cyberpower" but I suspect they may also be MSW since they tend to be a lot cheaper than APC, if not they may be extremely cheaply built PSW and if that is the case I would take a APC over the Cyberpower.
APC has a number of pure sine wave models, mostly in the Smart-UPS series. The Smart-UPS 750VA (SMT750) is just one of them...
โNov-12-2017 07:20 PM
โNov-12-2017 02:50 PM
โNov-12-2017 02:10 PM
โNov-11-2017 04:14 AM
โNov-11-2017 04:09 AM
โNov-11-2017 03:46 AM
โNov-10-2017 06:42 PM
